HOW TO FIX NO AUDIO PROBLEM IN FLASH (4 SOLUTIONS)
  • March 20, 2007
  • 14 replies
  • 20926 views
This solution is for WINDOWS ONLY!!! Unfortunately I believe it is a bug in flash itself as I have read more than one instance of this same no audio problem occuring on MAC'S and LINUX based systems as well. IF YOU KNOW OF SOLUTIONS TO THE MAC OR LINUX BASED PROBLEMS, PLEASE POST THEM IN THIS THREAD.
Description of the problem: Video sites such as YouTube, VideoSift, Break, Google Videos, Yahoo, and a plethora of others do not stream embedded audio. Viewing a YouTube video, for example, on VideoSift.com results in the video playing back with no audio. However, by going directly to YouTube and playing back the same video, it appears to work.
THERE ARE SEVERAL POSSIBLE SOLUTIONS.
Problem: You may be missing your WAVEMAPPER driver.
Cause: Wavemapper driver was removed during installation or updating of the Flash Player. It might not necessarily be Flash that removes it but apparently something does.
Solution #1: Google "Flash No Audio WAVEMAPPER" for directions, its been covered a bunch, but basically requires running REGEDIT and readding the WAVEMAPPER key to the appropriate location and value in the registry. Its not as difficult as it sounds.
http://weyland.be/wrdprss/index.php/2006/08/22/no-sound-in-macromedia-flash-player-9/
if your wavemapper key is installed correctly...
Possible Cause: Corrupted or damaged flash content preventing audio streaming from working correctly.
Soltuion #2: Run CC Cleaner and delete only cached Flash content. It is a free program, again just google "download CC Cleaner". This particular solution worked for me.
If CC Cleaner also does not work, the description of your problem may differ slightly. In my case on several computers, one day it worked, the next day it didnt. If it never worked, this would be a logical solution for you. One variation of this that I have found is to create a new Windows User Account and log into it. The reason the CC Cleaner method may work better is that the User Accounts have their own separate cache folders so a corrupted cache preventing audio playback on one profile will not be available on the other User Account to cause the same problem. I wont explain how to do this as the CC Cleaner will work better but if you are curious, yet again google "create new windows user accounts". I have also seen this method work on one of my affected computers but it did not fix the issue on the account I was having problems with.
http://www.ccleaner.com Install and run it, use it only to remove Flash under the Applications Tab, Multimedia, Adobe Flash Player. Check it and uncheck everything else, then hit Analyze then Run Cleaner.
Possible Cause: Missing Codec
Solution #2: Download and install the K-Lite Codec pack. Again, google it. A CODEC stands for COmpressor DECompressor and is a way to make audio and video files small enough to be transferred on the internet. There are a lot of different codecs and if you want to play back a video that was compressed using a particular codec, you will need that same corresponding codec to decompress your media source and view its content. Basically if you dont have a codec, you cant observe the content of the media. If you have a VCR and want to play back a DVD, you are out of luck unless you get a DVD Player. DivX and XVid Codecs are some of the very popular codecs used on the net, but to get those, I still suggest getting the K-Lite Codec Pack.
http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm
Solution #4: Go back to Flash 7. If it aint broke dont fix it. This Final alternative is only to be used as a last resort. You'll have to get rid of Flash 9 and go back to Flash 7. The really tricky part here is that you have to prevent Flash from auto updating itself. If you install Flash 7, and hit up YouTube, you'll immediately get Flash 9+ installed again with the same problems. So AFTER you uninstall Flash 9 (use Macromedias / Adobes uninstaller, yet again go google it) make a new text file and name it MMS.CFG, in the file put this one line "AutoUpdateDisable=1" (without the quotes) and put it in BOTH your c:\windows\system32 AND c:\windows\system32\Macromed\Flash folders. This will prevent flash from Auto Updating to 9+, then have to find some place to download the old flash 7 installer. I found one here. http://www.intercomm.com/downloads/Flash7. Only problem is that most sites will try to make you install Flash 9 and Flash 7 does not work on all sites, but it does on some like YouTube. DO NOT UPDATE TO FLASH 9+ IF YOU USE THIS METHOD.
You will probably want to IMMEDIATELY go to http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager05.html after installing Flash 7 and UNCHECK the update feature
I've tried to write this quick little guide at 3AM so Im not going to take more time to research other ways to fix this problem. If you have other solutions, such as for MAC and LINUX, or feel like adding on to something else that I've written here (links would be useful to the downloads I suggested) or correcting any mistakes I probably have made, please say so.
One of these solutions is bound to help you. Theres multiple causes for this no audio problem so there is obviously multiple fixes.
    November 6, 2008
    Thank you for the many many helpful suggestions to this VERY frustrating problem! None of the solutions worked for me, but the idea of checking out the speaker plug-in and setup helped. I just now discovered that my Audio default device (go to Control Panel, Sounds and Audio Devices, Audio tab - Sound Playback default device) had somehow gotten set to some Modem such-and-such... instead of my Soundblaster. I changed it back to the Soundblaster and OUALA - I have Sound again!!! Now when I go into the control panel, that modem doesn't even show up as a choice for the default device. Not sure how it got in there in the first place, but I'm so thankful that it's fixed. I've been without sound for months!
    I've spent the last week or so trying to fix this sound problem. I've tried all of the solutions on this page and quite a few others. None of them are working. I have a windows vista laptop so I just have the built in speakers. If someone could help me I would greatly appreciate it.
    I had problems with sound on a dell xps m1530 on vista when exporting flash movies from cs3, but I updated my sound drivers and miraculously everything works fine now.
    -Jerry H.
    New York Web Designers
    Royal CS
    Useful and effectual informations. Thanks
    Tercüme tercüme çeviri
    Does latest version solve this problem ?
    Thanks for the information. more knowledge for me
    Yeah Vista/Firefox and Youtube/Flash are not the best combination so far. Thanks for the information.
    I have sound but it is garbled while trying to play a camtasia training video .hard to hear what the instructor is saying any idea what causes this and how to fix
    Thanks
    Ken
    I had the same problem.
    commodity broker
    I too had NO SOUND in Flash players. I just finished building this computer for my wife. Installed late at night. Not many lights on. Keep this in mind...
    Yesterday I had a sound problem and had to adjust my surround sound to get ANYTHING, Had to go to 4 speakers even though I only had 2. Hmmmmmm.
    A couple of the suggestions talked about the Flash , Stereo / Surround Sound, and AC97 audio devices.
    After reading these posts I started the Free Napster [Flash] player and went back to my surround sound (Clicked on the little Xear 3D emblem to launch) and, while playing a 4 minute song, messed with the settings. Heard NO SOUND on 2 speakers, and Only 3D sound on 4 speakers. No sound from the 4 minute song.
    Checked where I plugged the Speaker cable in. It was NOT in the pretty green hole. Plugged the Green Plug into the Green Hole - ALL SORTS OF MUSIC NOW!!!!!
    Problem Solved!!! I had plugged the cable in to the computer at night...Into the WRONG hole. SO, the Surround Sound was telling the system that I had 4 speakers, and Flash wanted to ONLY go to stereo, which the Surround Sound was routing to non-existent speakers.
    I have only been building computers since 1993. You would think I know better by now, eh??
    Anyway , for those having problems, perhaps your speakers are not plugged in correctly or your surround sound is not configured correctly.
    As I found out, Not Everything is a driver fault. As a tech with 20 years of PC experience I have seen my fair share of Operator error - Now I are one :-)
    Ha... I created my account to comment on beezlebob666 valiant effort to assist people with various flash problems. You rock, you managed to put MOST of the solution into one post and walk people through it. Every other post I've seen literally seems to copy/paste from some tech booklet.
    So, I am running with XP home-MC edition, sp2, althlon64 4200+ w/ 2g ram and a nvidia8600gs. Never had any audio problems before, couldn't recall any new programs I've installed. I should point out I've been putting at least an hour(plus) a night into solving this one for the last 3-ish weeks.
    Solution 1) Did it, three times and in various version. No gas. Many restarts.
    Solution 2) Got it. Love the program, helped with other problems but no go.
    Solution 3) Installed every codec that exists and a few I am sure that don't. Nothing (Btw, you have solution 3 labeled "2")
    Solution 4) Did it, I even went crazy and tried a few stand-alone players and knock-offs. Nothing.
    Solution 5) See solution 4.
    Very thorough indeed.
    But, in the end I need to thank rnamen. I pulled what Troll calls a "Flashing 12" move... I had my stereo unplugged... I was checking my surround sound and noticed that I wasn't getting any front sound and just added that to the list of crap that I needed to work on. So, when I read your post, I thought it was possible. I just got a razor tarantula and I may have swapped the wrong audio-cord or unplugged something in error. Low-and-behold, I was plugged into the wrong damned line.
    Hi i have tried all of the suggested solutions and i still have no sound!!!
    Sound is fine on windows media, just not on youtube and other online video players.
    First (when it went wrong) i could only hear the sound very faintly out of one speaker, now there is no sound at all. But as mentioned there is sound on windows.
    Can any one help. Any ideas? In LAMENS terms (directions) if poss. Im not that knowledgable on pcs.
    Thanx
    Adobe Employee
    April 18, 2007
    For Mac OS, the following tech doc is most likely to help:
    http://www.adobe.com/go/41f8f08d
    Just wanted to thank you for posting this link, i-wt. I'd tried EVERYTHING to get the sound to work on my mac and this article finally showed me how to fix it. I was literally pulling my hair out, so thanks again!
