Jan 30, 2016 5:54 PM UTC
I have 2 users on this computer. One works fine. Other with flash settings same and correct doesnt work. I set compatibilty settings on IE11 and works but Edge has no compatibilty settings and is supposed to have flash built-in. I cant get edge to wo
2 users, I user fine. other same setting flash doesn't work. compatibility setting fix IE11 but edge doesn't have
    jeromiec83223024
    Jan 31, 2016 12:56 AM UTC
    First, confirm that ActiveX Filtering is configured to allow Flash content:
    https://forums.adobe.com/thread/867968
    Internet Explorer 11 and Edge introduce a number of changes both to how the browser identifies itself to remote web servers, and to how it processes JavaScript intended to target behaviors specific to Internet Explorer. Unfortunately, this means that content on some sites will be broken until the content provider changes their site to conform to the new development approach required by modern versions of IE.
    You can try to work around these issues by using Compatibility View:
    http://windows.microsoft.com/en-us/internet-explorer/use-compatibility-view#ie=ie-11
    If that is too inconvenient, using Google Chrome may be a preferable alternative.
    Jan 31, 2016 3:09 AM UTC
    Settings are correct. Edge says adobe flash is disabled but it is not!
    I already have used compatibility view settings to get it to work for IE11
    I cant get Edge to work
    The other user has the same settings and everything works fine
    2-3 weeks ago everything worked fine for both users. There may have been a flash or java update but no settings were changed so should work
