Need help: Not sure if Flash downloaded; IE says yes, but doesn’t work on Web
I have a problem. I downloaded Flash, but it's not working on my computer. (I
have Windows 7, Internet Explorer 11 and Norton Security.)
On Jun. 20, I went to download Flash on the Adobe web site. When asked to
download Flash, I clicked the "Run" button.
I thought I did everything right, until I went online. Every page with video told me
that I needed the most recent version of Flash, which I thought I had.
I tried figuring this problem out myself -- by seeing if my computer had Flash
installed on it.
I tried Adobe first, using this link: https://helpx.adobe.com/flash-player.html.
Adobe checked my computer and said either Flash is not installed or not
enabled.
Well, I thought, maybe it's installed and just not enabled.
With help from Adobe (https://helpx.adobe.com/flash-player/kb/install-flash-
player-windows.html), I checked Internet Explorer to see if Flash was installed or
enabled. And according to my browser, I did download Flash Shockwave Object
18.0.0.160 on Jun. 20, and Flash was enabled on my browser.
I'm a little confused. IE says I got Flash. But it's not working. What do I do?
Matthew
