Need Help to download Flash Player 11
  • February 1, 2013
  • 1097 views
I have Windows 7 operating system with Internet Explorer 64-bit. I am ab le to download Flash Player 11, dowdloading not a problem,but installation requires closing of internet explorer. Please give me step-by-step instructions to close it.
Correct answer samjones6
Vikram:
Your  instructions helped a little, but my problem was finally solved as explained below:
I completed the download/installation of Flash Player 11, but it did not work, it seemed to be "disabled".
I then  went to Adobe.com Flash Player Help (http://helpx.adobe.com/flash-player/kb/flash-player-games-video-or.html)
I followed the instructions:  Disable ActiveX Filtering (if using Internet Explorer 9)                                          Close Internet Explorer and then restart it.
Next I downloaded/installed Google Chrome (Flash player is integrated into  Chrome and enabled by default).
My problem has been solved and the Flash Player/Google Chrome works perfectly.
Thanks,Sam Jones
[private data removed]
VikramGaur
Adobe Employee
Adobe Employee
February 1, 2013
Welcome to Adobe Forums.
1) Launch Task Manager, Keyboard Shortcut : Ctrl+Shift+Esc or right click on Task Bar :
2) Under "Processes" Tab, you will iexplore.exe/
3) Right Click, Kill that process
Hope this helps !!
Vikram
samjones6AuthorCorrect answer
Vikram:
Thanks,Sam Jones
