I hope the following answers your question/issue.
As of Windows 8, Microsoft includes/embeddes Flash Player ActiveX Control in Internet Explorer (and Edge on Windows 10). This version of Flash Player is managed/owned by Microsoft, not Adobe and Adobe's uninstaller does not remove this version of Flash Player.
To remove the Flash Player ActiveX Control that is included/embedded in IeE/Edge on Windows 8 and above, and managed by Microsoft, run Microsoft's Update to Remove Flash Player: https://support.microsoft.com/en-us/help/4577586/update-for-removal-of-adobe-flash-player
Please read through the document carefully before running the update to remove Flash Player.
The link the update/patch files is in the Microsoft Update Catalog section, towards the bottom of the page. There are a total of 43 different update/patch files for the various Windows versions. You need to download the link that applies to your system, otherwise, the update may not work correctly.
If you experience issues running the update, please contact Microsoft for assistance as this is their update, not Adobe’s. Tell them you are trying to uninstall the Flash Player ActiveX Control that is included/embedded in IE browser and managed by them.
Sign up
To post, reply, or follow discussions, please sign in with your Adobe ID.
Sign inSign in to Adobe Community
Sign inEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
