Problem with Global Privacy Settings Panels IE9 & W7
After install of Flash 10.2.159.1 and reboot, the Global Privacy Settings Panels webpage opens in IE9 but does not display the several Settings "UI Panels" (http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.html).
I can get to some security settings UI via right click on a Flash player window and selecting “Settings …”.
Clicking “Global Settings …” there also opens webpage for Global Privacy Settings Panels but does not display panels. Can play Flash video, and Adobe About webpage shows 10.2.159.1 is installed, as does right click on Flash player open window in IE9.
Windows 7 Home Premium
Internet Explorer 9
Uninstalled Flash 10.2.153.1 via uninstall_flash_player.exe (10.2.159.1) and installed Flash 10.2.159.1 via install_flash_player_ax.exe (10.2.159.1); both downloaded from Adobe Flash website.
