Timeline for Flash with 64 bit operating systems
  • August 4, 2009
  • 1993 views
Has there been any timeline for when Adobe will put out a version on Flash Player that works with 64 bit operating sustems? I looked around the site and forums and couldn't find anything on it other than the fact that it was going to come out after Version 10. Approximately when might that be?
    This is for Windows 64 bit? If it is what I did was to create a shortcut to the Internet Explorer executable under Program Files (x86)\Internet Explorer. This runs the 32 bit Internet Explorer which Flash will install on, I use the 32 bit IE to surf the web sites that has Flash content.
    Sorry, but this is no answer on his question and no solution for using 64-bit Internet Explorer or 64-bit Firefox, isn't it?
    August 13, 2009
    Unfortunately all we can say at this time is "we're still working on it".   It will happen, I just cannot say when.
