johnf31895023
Using Adobe Flash Player with a Samsung Smart TV
  • January 3, 2017
  • 4 replies
  • 211772 views
I recently purchased a Samsung Smart TV.    I want to watch Big Sky Conference Basketball games using the link to web sites on the TV.   I am able to access the "Watch Big Sky" web site and get all the way along the system to the correct game and the screen to watch it.   When the game comes on and I try to get it up on the screen, I get a screen message that says I need Adobe Flash Player to watch the game itself.
I go back to the Adobe web site to download the Flash Player and get a message that says that application is not available.
How do I get over this hurdle.
Samsung, from some foreign country, says it is not their problem.
The season is just starting.  I need help and Adobe has no way to directly contact them.   Their support system is entirely composed of referring me to this web site.
Hope someone is out there.
Correct answer _maria_
Flash Player is only supported on desktop systems.  See Adobe Flash Player | Tech specs
The work-around would be to connect your computer via HDMI cable and watch the content that way.
Facebook
You don't need adobe flash for the samsung... go to the apps and activate the app you want to view such as hbogo.  You will get a pin but you have to enter the hbogo activation website through your computer while you have the tv pin on the screen, once activated in this manner you will be able to view the shows without adobe flash player
I think the OP is trying to watch a feed through a website in the samsung smart TV browser. for embedded video, you need adobe flash player (or other player, like quicktime) to view the videos but the browser that currently comes with the TV cannot support flash because it is a computer program and not something that can be installed into the browser APP like an extension on a computer...
this seems like something samsung could easily build though...
_maria_
_maria_Community ManagerCorrect answer
Thanks for the honest response. from the Adobe staff...
Is this something that is being looked into in the future?
I work for city government and we have an issue viewing our city meetings through a government portal that needs flash to play on our digital signage smart TV's. and for the same reason, our own government content cannot be played in our city hall. ( we have a digital signage workaround in place but it is going to cost alot for the players and licensing).
I understand this issue is because of the browser that comes with Samsung smart TV's, but isn't it possible to build a player enabled app for smart TV's? Adobe is pretty crafty and I am sure you have a couple good programmers who could lead the charge on this! (and quite possibly corner the smart TV browser market!)
just a thought!
If it works out, remember, I called it first, Ill take my normal 10% cut!! lol
thanks
January 13, 2019
Go on your tv app search, search "xfinity beta", install, enjoy!
Amrita Gangwani
Adobe Employee
Adobe Employee
January 4, 2017
Thanks for reporting the issue, if you could reply with following details it would be easy to troubleshoot the problem.
  • Operating system version
  • Web browser and version
  • Flash Player version
  • Explain your problem in step-by-step detail if possible
  • A direct link to a web page that demonstrates the problem
  • If you get error messages, please quote them exactly, or provide a screenshot
Meanwhile, you may also refer to following links:
Installation problems | Flash Player | Windows 7 and earlier
Installation problems | Flash Player | Mac
Thanks!
johnf31895023
Amrita,
Thanks for your reply.
I don’t know if this will be of any assistance to you because I am working with a television not a computer. I am able to access my browser directly from the Televison.
OS is X Yosemite version 10.10.5
Browser is Safari version 10.0.2
Flash player version is whatever one they give me to download. I think that they are up to
I am trying to watch a University of Montana men’s basketball game on my TV. I can get to the site that streams the game through the Bigskyconference.com <http://bigskyconference.com/> web site and using drop down menus for watch big sky and then on to the game. The problem only occurs when the game is actually being streamed and cannot be duplicated until then. When you get all the way through the site and the game is on, a screen message occurs saying that the game cannot be viewed until Flash Player is installed. When I go to the Flash Player website to download that program, I get a message that says that the program cannot be downloaded (I forget the actual message) As I said above there is no way to duplicate this situation until the game is actually on.
Hope this helps. It is all I can do.
John J. Fitzpatrick
