is there a way to send content of textflow to ms word with same format
  • July 18, 2011
  • 1126 views
i want a way to send  content of textflow to ms word with same format
i think with
Clipboard.generalClipboard.setData  and RICH_TEXT_FORMAT withe code
which p.getText() is text of paragraph (p)
Clipboard.generalClipboard.setData(ClipboardFormats.HTML_FORMAT,p.getText() );
but i get error
how can i solve this problem
thanks in advance
Adobe Employee
July 19, 2011
Have a look at my reply in http://forums.adobe.com/thread/878480?tstart=0
July 19, 2011
mr Jin-Huang thanks for your time
your answer is about how to make custom convert to text flow but not to convert to rtf markup
my question is
how can i convert to rtf markup ?
or if i misunderstand can you explain more
July 22, 2011
I think if you just use the TFL exporter to export the text to HTML and use that as the clipboard format it will work, I manage to export table with format and everything to clipboard this way and paste them into excel and word with no problem.
it pase in word with html format syntax
if you have example pls post it
July 18, 2011
i think there is no answer
i googeld about it
found nothing
