Strange behaviour when running parameterized test
  • October 24, 2011
  • 4362 views
I am using Flex 4.5 and FlexUnit 4.1 inside of the Flashdevelop IDE and I am experiencing some very strange behaviour.
If I have 5 parameters to my test the test runs fine. When I add a sixth parameter of the type Array, I get the following error:
"TypeError: Error #1009: Cannot access a property or method of a null object reference."
Please see below for my example code.
The following parameterized test case runs without a problem:
package {
    import org.flexunit.runners.Parameterized;
    [RunWith('org.flexunit.runners.Parameterized')]
    public class ParameterizedTest {
        [Parameters]
        public static var testData:Array = [
            [1,1,new Array(),1,1]
        public function ParameterizedTest(
            param1:uint,
            param2:uint,
            param3:Array,
            param4:uint,
            param5:uint
        ):void {
        [Test]
        public function testOne():void {
            // Test to go here.
When I add an Array as the sixth parameter :
package {
        [Parameters]
            [1,1,new Array(),1,1,new Array()]
            param1:uint,
            param2:uint,
            param3:Array,
            param4:uint,
            param5:uint,
            param6:Array
        ):void {
        [Test]
            // Test to go here.
I get this error :
com.berog.proj_drum_machine.tests.matrix_test_suite.test_cases::MatrixConstructorTest.testOne (1,1,,1,1,) .
    at flex.lang.reflect::Constructor/newInstanceApply()
    at TestClassRunnerForParameters/createTest()
    at org.flexunit.runners::BlockFlexUnit4ClassRunner/methodBlock()
    at org.flexunit.runners::BlockFlexUnit4ClassRunner/runChild()
    at org.flexunit.internals.runners::ChildRunnerSequencer/executeStep()
    at org.flexunit.internals.runners.statements::StatementSequencer/handleChildExecuteComplete()
    at org.flexunit.internals.runners.statements::StatementSequencer/evaluate()
    at org.flexunit.runners::ParentRunner/run()
    at org.flexunit.runners::Parameterized/runChild()
    at org.flexunit.runners::Suite/runChild()
    at org.flexunit.runner::FlexUnitCore/beginRunnerExecution()
    at org.flexunit.runner::FlexUnitCore/runRunner()
    at org.flexunit.runner::FlexUnitCore/runRequest()
    at org.flexunit.runner::FlexUnitCore/runClasses()
    at Function/http://adobe.com/AS3/2006/builtin::apply()
    at org.flexunit.runner::FlexUnitCore/run()
    at com.berog.proj_drum_machine.tests::TestMain()
com.berog.proj_drum_machine.tests.matrix_test_suite.test_cases::MatrixConstructorTest.testOne (1,1,,1,1,) E
Time: 0.013
There was 1 failure:
1 com.berog.proj_drum_machine.tests.matrix_test_suite.test_cases::MatrixConstructorTest.testOne (1,1,,1,1,) TypeError: Error #1009: Cannot access a property or method of a null object reference.
FAILURES!!! Tests run: 1, 1 Failures:
Can anyone help me?
Thanks for including a test case. I will try to replicate this morning
Mike
October 25, 2011
Hi Mike,
Were you able to reproduce the errors I was experiencing?
Ben
Hi Mike,
Thanks so much for looking into this.
I think I'm going to make the change and recompile.
Where should I file the bug?
-Ben
There is a flexunit category on bugs.adobe.com
mike
