Adobe Employee
Dec 23, 2009 11:46 PM UTC
[svn:fx-3.x] 13209: Adding same fix for SDK-23838 and SDK-24205 to 3. x from trunk.
Revision: 13209
Revision: 13209
Author: klin@adobe.com
Date: 2009-12-23 15:45:53 -0800 (Wed, 23 Dec 2009)
Log Message:
Adding same fix for SDK-23838 and SDK-24205 to 3.x from trunk.
The dropDown was not receiving changes to styles nor dataproviders. This was a result of not recreating the dropDown each time it was shown. I've changed the default of the flag for destroying the dropDown to be true. I've also modified the code to only not destroy the dropDown when it is showing or being shown. I?\226?\128?\153ve also moved some of the code in the animation handler to check for a null dropDown first before destroying it.
QE notes: No
Doc notes: No
Bugs: SDK-23838, SDK-24205
Reviewer: Jason
Tests run: checkintests, ComboBox
Is noteworthy for integration: No
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-23838
http://bugs.adobe.com/jira/browse/SDK-24205
Modified Paths:
flex/sdk/branches/3.x/frameworks/projects/framework/src/mx/controls/ComboBox.as
