Textflow link element doesn't work after append to an existed textflow
  • November 10, 2010
  • 6468 views
It's a strange problem
I have two textflow container : RichEditableText
the first one I new the textflow2 everytime I clicked the button,and append a link returned by getElement
the second one I initially new a textflow and reused it to append new link returned by the same function getElement
but the strange thing is , the first one works just fine ,but the second one 's link seems invalid with no hand cursor nor function
thanks a lot for any clue or comment
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                           xmlns:s="library://ns.adobe.com/flex/spark"
                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="400" minHeight="300">
        <s:layout>
                <s:BasicLayout/>
        </s:layout>
        <fx:Script>
                <![CDATA[
                        import flashx.textLayout.elements.LinkElement;
                        import flashx.textLayout.elements.ParagraphElement;
                        import flashx.textLayout.elements.SpanElement;
                        import flashx.textLayout.elements.TextFlow;
                        [Bindable] public var textFlow:TextFlow = new TextFlow();
                        [Bindable] public var textFlow2:TextFlow = new TextFlow();
                        protected function button1_clickHandler(event:MouseEvent):void
                                textFlow2 = new TextFlow();
                                textFlow2.addChild(getElement());
                                textFlow.addChild(getElement());
                        private function getElement():ParagraphElement{
                                var linkSpan:SpanElement = new SpanElement();
                                linkSpan.text = "link";
                                var link:LinkElement = new LinkElement();
                                link.addChild(linkSpan);
                                link.href = "event:ok"
                                var p:ParagraphElement = new ParagraphElement();
                                p.addChild(link);
                                return p;
        </fx:Script>
        <fx:Declarations>
        </fx:Declarations>
        <s:RichEditableText editable="false" text="RichText" width="180" height="165"  textFlow="{textFlow2}" />
        <s:RichEditableText editable="false" x="196"   text="RichText" width="180" height="165" textFlow="{textFlow}" />
        <s:Button x="116" y="217" label="button" click="button1_clickHandler(event)"/>
</s:Application>
I'm facing the same issue and i'm using 4.5 SDk.
Here's my code. Works fine if textFlow value is not bindable, else shows nothing(Blank).
   creationComplete="init()">
<s:layout>
<s:VerticalLayout/>
</s:layout>
<fx:Script>
<![CDATA[
import flash.text.engine.FontWeight;
import flashx.textLayout.conversion.TextConverter;
import spark.utils.TextFlowUtil;
private var hi:String="my code"
private var cnt:int=10;
var markup:String="hello";
private var text:TextFlow;
private var levelName:String = "family"
public function init()
trace("here");
markup += "world";
if(levelName == "family"){
markup +="<span fontSize='15' color='#ff0000' fontFamily='Verdana'>"+ hi + "</span> (<span fontSize='12' color='#007fc5' fontFamily='Arial'>"+cnt+") > </span>";
trace("string::"+markup)
text=TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT);
private function clickBtn(event:MouseEvent):void{
markup += "world";
rTxt1.textFlow =TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT);
</fx:Script>
<s:RichText>
Hello
<s:span fontSize='16'>BIG NEW</s:span>
World!
</s:RichText>
<!-- Or the TextFlow child tag. -->
<s:RichText id="rTxt" textFlow="{text}"/>
<s:RichText id="rTxt1" />
<s:Button click="clickBtn(event)" label="Click"/>
</s:Application>
Adobe Employee
June 30, 2011
Replace the line
rTxt1.textFlow =TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_F ORMAT);
with
var imp:ITextImporter = TextConverter.getImporter(TextConverter.TEXT_FIELD_HTML_FORMAT);
rTxt1.textFlow = imp.importToFlow(markup);
Then your code will work.
flashx.textLayout.convertion.TextConverter is the converter in TLF, which work well. TextFlowUtil is not under our control.
Is the result OK for you after you run the code as follows?
    <s:layout>
        <s:VerticalLayout/>
    </s:layout>
    <fx:Script>
        <![CDATA[
            import flashx.textLayout.conversion.*;
            [Bindable]
                trace("here");
                markup += "world";
                text = TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT);
                markup += "world";
    </fx:Script>
    <s:RichText>
        Hello
        <s:span fontSize="16">BIG NEW</s:span>
        World!
    </s:RichText>
    <s:RichEditableText id="rTxt1"/>
    <s:Button label="Click" click="clickBtn(event)"/>
</s:Application>
Thanks a Jin, its working fine now.
I found one more way of doing the same, please have a look below:
<s:layout>
<s:VerticalLayout/>
</s:layout>
<fx:Script>
<![CDATA[
import flashx.textLayout.conversion.ITextImporter;
[Bindable]
private var textFlowTxt:TextFlow;
private var markup:String="hello";
private var levelName:String = "family";
private function createTextFlow():TextFlow {
var htmlText:String = "<span fontSize='15' color='#ff0000' fontFamily='Verdana'>"+ hi + "</span> (<span fontSize='12' color='#007fc5' fontFamily='Arial'>"+cnt+") > </span>";
var textFlow:TextFlow = TextFlowUtil.importFromString(htmlText, TextConverter.TEXT_FIELD_HTML_FORMAT );
return textFlow;
</fx:Script>
<s:RichText>
Hello
World!
</s:RichText>
<s:RichText id="rTxt" textFlow="{createTextFlow()}"/>
</s:Application>
Adobe Employee
November 10, 2010
I can reproduce this in TLF 2.0 and filed a bug.  I did observe that if I click on textFlow2 the link begins to work.  What version of TLF are you using?
Richard
Thanks for the reply
I am using flex sdk 4.1 bundled version.I don't know which version exactly, is that 1.1?
is there a way to workaround ? If I switch to tlf2.0 or newer version the problem might gone?
Adobe Employee
November 11, 2010
Yes - Flex 4.1 is using TLF 1.1.  Thanks.
I have fixed this in 2.0.  For a 1.1 workaround you can do this:
        <s:layout>
                <s:BasicLayout/>
        </s:layout>
        <fx:Script>
                <![CDATA[
                    import flashx.textLayout.compose.StandardFlowComposer;
                    import mx.core.mx_internal;
                    import flashx.textLayout.tlf_internal;
                                ret2.mx_internal::textContainerManager.tlf_internal::convertToTextFlowWithComposer();
                                ret.mx_internal::textContainerManager.tlf_internal::convertToTextFlowWithComposer();
                                link.href = "http://www.adobe.com"
                                p.addChild(link);
                                return p;
        </fx:Script>
        <fx:Declarations>
        </fx:Declarations>
        <s:RichEditableText id="ret2" editable="false" text="RichText" width="180" height="165"  textFlow="{textFlow2}" />
        <s:RichEditableText id="ret" editable="false" x="196"   text="RichText" width="180" height="165" textFlow="{textFlow}" />
</s:Application>
