FMLE does not work publishing though AMS server connection succeeds
Hello Adobe Support,
Using Adobe Media Server we've run into a problem.
Occasionally "FlashMediaLiveEncoder does not work on publishing, though AMS server connection succeeds."
As soon as clients are connected to AMS, they get disconnected and cannot publish a stream.
After restarting AMS (command: "/opt/adobe/ams/amsmgr server ams restart") it comes back to normal.
Seems amscore hangs up for a while.
AMS version: 5.0.6 r9003 x64
OS: Amazon Linux 6.3
core.00.log below:
2015-01-08 00:53:44 22267 (i)2581247 Core (22267) disconnected from edge. -
#Date: 2015-01-08#Fields: date time x-pid x-status x-ctx x-comment
2015-01-08 00:53:44 6153 (i)2581247 Core (6153) disconnected from edge. -
2015-01-08 00:54:01 22267 (e)2581279 Assert failed in tincan/util/TCAsyncIO.cpp line 1948 -
We've found two amscores exist in 'ps auwxff' like below when this problem happens. Does this matter?:
Sl 2014 4:32 ./amsmaster -console
Sl 2014 6:07 \_ /opt/adobe/ams/amsedge -edgeports :1936 -coreports 127.0.0.1:19350 -conf /opt/adobe/ams/conf/Server.xml -adaptor _defaultRoot_ -name _defaultRoot__edge1 -edgename edge1
Sl 2014 272:07 \_ /opt/adobe/ams/amscore -adaptor _defaultRoot_ -vhost _defaultVHost_ -app -inst -tag _1 -console -conf /opt/adobe/ams/conf/Server.xml -name _defaultRoot_:_defaultVHost_:::_1
Sl Jan04 1:36 \_ /opt/adobe/ams/amscore -adaptor _defaultRoot_ -vhost _defaultVHost_ -app -inst -tag _2 -console -conf /opt/adobe/ams/conf/Server.xml -name _defaultRoot_:_defaultVHost_:::_2
After restarting AMS only one core exists:
Sl 2014 272:23 \_ /opt/adobe/ams/amscore -adaptor _defaultRoot_ -vhost _defaultVHost_ -app -inst -tag _1 -console -conf /opt/adobe/ams/conf/Server.xml -name _defaultRoot_:_defaultVHost_:::_1
pstack of one ams process:
amscheck tool log. It returns code 64512 "Operation timed out":
We have gcore files for each amscore process.
Let us know if you want them for investigation.
We want to solve this problem ASAP.
Do you have any idea what is happening here? Any advice would be helpful.
Yusuke
