Oct 6, 2011 5:01 PM UTC
Send sound with stream (both sound and mic audio)
I have a broadcasting project that I've got where the host of the show can have multiple sound effects they can use on their show.  I'm wondering if the only way to go about this is for all the clients listening to the show need to download the mp3 of that sound effect or if the sound effect could come from the host ...like combining his mic (for his voice) but also straight audio (the sound effect) into the stream.
    calmchessplayer
    Oct 6, 2011 9:42 PM UTC
    well I've never done this but I'm about to. Any way I would attempt to make two netstreams 1 for the constant audio stream and 1 to play sounds.  I would think the second sound will play over the PC soundcard at the same time. because i can have two applications such as SKYPE and  a Flash App open at the same time and hear both. So I know the PC sound card can handle it. I won't have time to test this untill next week. So if you try it please report your findings to this thread.
