Apr 23, 2005 3:06 AM UTC
Fonts bundled with Creative Suite 2 (and individual CS2 products)
The attached PDF lists all the fonts bundled with Creative Suite 2 and the individual CS2 applications.
Enjoy!
T
    Apr 8, 2009 10:58 AM UTC
    Has the PDF that Mister Phinney refers to been removed?!?
    I'd bookmarked this page because I need to do a font audit for my college. Now I can't find the PDF.
    I'm just going to attach a wee PDF so I can see where they appear in a post. That might solve my problem but if anybody has Mr. Phinney's PDF, could they repost it?
    I see where it says attachments now and this is nowhere to be seen in the original post. Does anybody have that list (preferably as a .csv/.xls but I'll cope with any format)?
    Apr 8, 2009 3:12 PM UTC
    This is a list I made years ago. Perhaps it is of some use. The Brioso fonts were an incentive for purchasing CS2, and not part of the standard package.
    Adobe Garamond Pro - set(6)
    Adobe Jenson Pro - set(8)
    Bernhard Modern Std - set(4)
    Birch Std - set(1)
    Brioso Pro Opticals - set(40)
    Brioso Pro Poster - set(2)
    Brush Script Std - set(1)
    Caflisch Script Pro - 1 of 4 - regular
    Adobe Caslon Pro - set(6)
    Century Old Style Std - set(3)
    Chapparel Pro - set(8)
    Charlemagne Std - set(2)
    Courier Std - set(4)
    Giddyup Std - 1 of 2
    Kozuka Gothic Pro - 2 of 6 - medium, heavy
    Kozuka Gothic Std - set(6)
    Letter Gothic Std - set(4)
    Lithos Pro - set(5)
    Mesquite Std - set(1)
    Minion Pro - 6 of 8
    Minion Std - set(1) - black
    Myriad Pro - set(10)
    Myriad Pro Condensed - set(10)
    Myriad Wild Std - set(2)
    News Gothic Std - set(4)
    Nueva Std - set(6)
    Poplar Std - set(1)
    Prestige Elite Std - set(4)
    Rosewood Std - set(2)
    Stencil Std - set(1)
    Trajan Pro - set(2)
    Viva Std - 3 of 9
    Warnock Pro Opticals - set(32)
    Adobe Wood Type Ornaments Std - set(1)
    Adobe Ming Std - light
    Adobe Myungjo Std - Medium
    Kozuka Mincho Pro - 4
    Kozuko Mincho Std - 6
    Ryo Display Std - 5
    Ryo Text Std - 4
    Apr 8, 2009 4:42 PM UTC
    Wow. Thanks a million Tom. That's going to be super useful. Short of the actual, official word from Adobe that's probably the best response I could hope for. Ta.
    Ramón G Castañeda
    Oct 19, 2007 3:08 PM UTC
    Gopal,
    Your post has really nothing to do with Typography.
    This is a description of this forum on the same page where you found this thread:
    Typography
    A place to talk about type, typography, and typesetting. Help each other identify typefaces. Get suggestions about what typefaces work well together. Offer opinions about spacing, justification, punctuation, and the like.
    However, for more technical questions about installing fonts, or working with service bureaus, and things like that you might find more help in the ATM/Type forums. Or for questions about how specific applications work with type it might be better to post in the product forums. Go to: http://www.adobe.com/support/forums/index.html for the complete list.
    For a faster and better answer, try posting in the InDesign forum or, even better, in the developer forums.
    Oct 19, 2007 1:49 PM UTC
    hi friends,
    I am building an application in asp.net in which my task is to create a pdf file by using the Adobe Indesign CS2 in asp.net.
    I am using the code which is found from the net but on running this is given an error That:
    "System.UnauthorizedAccessException: Access is denied."
    now tell me about this error and what i have to do to achieve this task. this is really urgent one
    atleast reply if u don't know the answer also please.......
    Here's my code::
    Imports System
    Imports System.Data
    Imports System.Configuration
    Imports System.Web
    Imports System.Web.Security
    Imports System.Web.UI
    Imports System.Web.UI.WebControls
    ' Imports System.Web.UI.WebControls.WebParts
    Imports System.Web.UI.HtmlControls
    Imports InDesign
    Public Class _Default
    Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
    Dim cstrInddFile As String = Server.MapPath("~/Archieve/yourstory_backcover1.indd")
    Dim cstrXMLFile As String = Server.MapPath("~/Archieve/xml1.xml")
    Dim cstrOutputFile As String = Server.MapPath("~/Archieve/out.pdf")
    Dim indAppType As Type = Type.GetTypeFromProgID("InDesign.Application")
    Dim objInDesign As InDesign.Application = DirectCast(Activator.CreateInstance(indAppType, True), InDesign.Application)
    Dim objDoc As InDesign.Document = DirectCast(objInDesign.Open(cstrInddFile, False), InDesign.Document)
    objDoc.ImportXML(cstrXMLFile)
    Dim objPreset As InDesign.PDFExportPreset=DirectCast(objInDesign.PDFExportPresets.LastItem(),InDesign.PDFExportPreset)
    objDoc.Export(idExportFormat.idPDFType, cstrOutputFile, False, objInDesign.PDFExportPresets("Press"))
    End Sub
    End Class
    Sep 8, 2007 9:35 PM UTC
    I'm a newbie to CS2 Illustrator and I need to install IT Franklin Gothic Demi. If it doesn't automatically come with my CS2 Illustrator, what do I do?
    Sep 8, 2007 9:55 PM UTC
    ...what do I do?
    If you're on a PC and have ANY of the following Microsoft products, a
    truetype version is included with:
    Access 97 SR2, Office 2000 Premium, Office 97 Small Business Edition
    SR2, Office 97 SR1a, Office Professional Edition 2003, PhotoDraw 2000,
    Picture It! 2000, Picture It! 2002, Picture It! 98, Publisher 2000,
    Publisher 97, Publisher 98, Works 2002
    Otherwise, you can always buy it.
    It's available from Adobe and just about every other major font vendor.
    By the way, that's ITC Franklin Gothic (not IT)
    - Herb
    Jul 18, 2007 4:06 AM UTC
    What fonts are required in CS2 .
    Mar 26, 2007 3:43 PM UTC
    ghj
    Mar 26, 2007 2:14 PM UTC
    ghj
    Mar 9, 2007 8:25 PM UTC
    On the Mac (Library --> Application Support --> Adobe --> Fonts --> Reqrd --> Base)
    The only fonts I have in my Reqrd folder are the four members of the Myriad (PostScript Type 1) family. These are not to be confused with the optional OpenType versions.
    AFAIK, the only other fonts you need are the basic fonts required by your operating system.
    Mar 9, 2007 5:34 PM UTC
    greet,
    As far as I know, only your basic system fonts.
    Mar 9, 2007 2:19 PM UTC
    I would like to clean up my fonts? What fonts are required in CS2
    BobLevine
    Mar 9, 2007 6:04 PM UTC
    There's an Adobe/Fonts folder created when you install the suite. Within
    that folder is another subfolder that contains the required fonts...DO
    NOT DELETE OR MOVE them.
    Bob
