I have to modify a PDF-form a coworker created some years ago. Two pretty big if-then-else scripts (~ 450 lines) used to work well. And they still work well if you use Acrobat Pro or MS-Edge (sic!), but fail with Adobe Reader.
I’ve changed the huge if-then-else to an array – again, works fine in Pro and Edge – but not in Reader...
Any Idea what might go wrong. Aside from the size it is a simple if-then-else script, nothing special about it. Other JS in this very form work fine with Reader too …
Additional Question: Actually the two scripts should be a big one. I thought, when changing to an array I could combine them in a single field. But there seems to be a limit to the number of lines allowed in Acrobat. Though there is no error, values at the end of this array are simply not found …?
Thank you
Thank you all!
I did a lot more reworking on these forms as I planed ... Though I still can't tell where the problems came from. They simply vanished as I worked my way through the form. Well apparantly there was to much ... in the whole form (and still is), but for now they work fine.
I still have some questions concerning arrays, but I think I set up a speciel test-form and a separate thread for that next year.
I wish you a peaceful Christmas and a good start into the New Year!
Thank you all!
Get ready! An upgraded Adobe Community experience is coming in January.
Learn more
