For some reason after obtaining a subscription to use Technical Communication Suite, I'm unable to activate my Acrobat Pro that should come with it.
Since it's a subscription, there's no serial number to enter. It knows I have an Adobe account, but it won't acknowledge that as being part of my Technical Communication Suite subscription.
Check with Adobe Support - IIRC you still download and install TCS software and use a serial number even if you are running a subscription.
When I've gone through the steps to get to that point, it routes me to the forums when it comes to "activation and license" issues.
You'll need to phone them or shoot an e-mail to TechComm@adobe.com.
