Sony A1 II raw images were being imported as “Embedded and Side car”.
Community Beginner ,
Feb 21, 2025 Feb 21, 2025
I recently noticed that ARW files imported to Lightroom Classic 14.2 from my new Sony A1 ii are not displaying blues correctly and are also looking very washed out. In both library and develop modes the bottom thumbnail scroll is displaying the colors correctly until I select a photo to develop. At that point both the main image and the thumbnail shift towards a very green hue. This isn't happening on any images I'm importing from my A7RV. It is very noticeable on blue sky images. Once the image has been deselected for a few moments, the thumbnail reverts to the correct color.
I dont believe it's the camera causing the issue, as my settings have been double checked and mirror those of the A7RV. Furthermore, this is a new issue.
I've also used the DNG converter and am having the same issue with all DNG's from the A1 ii
Any and all help would be greatly appreciated!
Barry
[Moved from ‘Bugs’ to ‘Discussions’ by moderator, according to forum rules.]
TOPICS
Windows
5.8K
correct answers 2 Correct answers
Community Beginner , Feb 22, 2025 Feb 22, 2025
Problem solved. For some reason the raw images were being imported as “Embedded and Side car”. Changed that to “standard” and all is good.
Thank you to those who reached out to help!
Explorer , Aug 30, 2025 Aug 30, 2025
@lhglhgl No need, the latest version of lightroom fixes the problem
Explorer ,
Jul 04, 2025 Jul 04, 2025
Explorer ,
Jul 05, 2025 Jul 05, 2025
Thank you very much! It works in LR Classic, but there is no solution for Lr CC, right?
@Barry36212844cdld could you mark this as unsolved? Cause it really isnt solved.
Explorer ,
I don't have LR CC unfortunately I only use LR Classic, yes you have to put the post in unresolved please.
Aug 29, 2025 Aug 29, 2025
I can't access your google drive link. Can you repost?
Explorer ,
