pascalm3859019
Mar 21, 2025 11:55 AM UTC
In Development
P: Photoshop doesn't use 30 bit display depth, banding issues in light grey tones.
I accidentally discovered that PS on Windows doesn't use 30 bit display depth any more. This happens in both Photoshop versions, the actual beta (27.0.1 20251006.m.3249 97696d7 x64) and the production version (26.11.0 20250918.r.18 a87e57f x64). You can simply reproduce the result by starting with a new 16bit or 32bit image and draw a gradient with relative bright grey tones. Severe banding will appear like in 8bit images.
If you use the Camera RAW filter on this picture the gradient is displayed very smooth without banding.
30 bit is supported on my system as you can see in the screenshots attached. Nvidia driver is the latest Studio driver (581.29 from 2025-09-10).
Earlier versions of PS were able to use 30 bit display depth without problems.
Please scroll down for screenshots.
Thanks for your help in advance!
Adobe Photoshop Version: 27.0.1 20251006.m.3249 97696d7 x64 (beta, PublicBeta)
Anzahl der Starts: 565
Betriebssystem: Windows 11 64-Bit
Version: 11 oder höher 10.0.26100.6584
Systemarchitektur: AMD CPU-Familie:15, Modell:4, Stepping:0, AVX2, AVX-VNNI, AVX-512, Hyper-Threading
Physischer Prozessor: 16
Logischer Prozessor: 32
Prozessor-Taktfrequenz: 4300 MHz
Eingebauter Speicher: 65189 MB
Freier Speicher: 41808 MB
Für Photoshop verfügbarer Arbeitsspeicher: 51127 MB
Von Photoshop verwendeter Arbeitsspeicher: 70 %
Absturz-Handler: Adobe
DCX Version: 9.11.1
SAM SDK Version: 14.3.4
ACP.local Status:
- SDK Version: 5.8.2
- Core Sync Status: Reachable and compatible
- Core Sync Running: 7.7.0.5
- Min Core Sync Required: 4.3.66.28
Client-SDK-Version für Live-Bearbeitung: v5.3.2
.Adobe Firefly: Verwende eine beliebige generative KI-Funktion, um die neueste Version anzuzeigen.
OpenColorIO-Version: 2.4.2
C2PA-Bibliotheksversion: adobe_c2pa/0.14.2 c2pa-rs/0.43.0
NGL-Version: 1.42.0.5
Sophia Info:
- Ps_Feature_Flag, Feature Flag URL (AEM) campaignID:49ef7e1b-397c-4de0-be48-6d09b6170752#ddf8400b-3f21-4b8e-be2b-c9272c2bf749::: variationID:dbc69741-dbd4-40d6-9a25-cefd0aa36a08-0:::94919410-abe9-473b-bcf9-721b8c5aaddb#bc415ea8-98f3-462a-a750-2e42ba198454, caa3ea5e-1ed2-43cf-bd40-84b73c68854d#5bca76c0-fbe2-4137-be08-92e2e3955633, ccd90257-20ff-425c-9fe1-46d56a84faa6#5bca76c0-fbe2-4137-be08-92e2e3955633, d7e68bbf-a4e2-4247-95f3-6e0ebe96f180#ddf8400b-3f21-4b8e-be2b-c9272c2bf749, 3116a8d8-f11c-41c8-be63-a694b12379b9#5bca76c0-fbe2-4137-be08-92e2e3955633, 98333258-8d4d-47b1-890d-442cc46139bd#86a7b901-68fa-48db-9eb8-e1b59d3bfc33::::::0430853e-9dfe-41a1-802f-dd5dad68b932
Tafel: Aktiviert.
Tafel Dokument erstellen: Deaktiviert.
D3D12Verformungs-Renderer: Deaktiviert.
Präzises Farbmanagement für HDR-Anzeige: Aktiviert.
Alias-Ebenen: Deaktiviert.
Fernlicht: Deaktiviert.
Wintab Digitizer Services
Spec Version 1.4
Impl Version 1.39
Num Devices 1
PSBenKonfig-Einträge:
- K uSty UseSystemStylus 0
Bildkachelgröße: 1028 KB
Bildcache: 4
Schriftvorschau: Riesig
HarfBuzz – Version: 8.4.0
Textengine: ATE 7.9.0 (d611361)
======= GPU
Native API stabil: Wahr
OpenCL API stabil: Wahr
GPUDeny: 0
GPUForce: 0
useGPU: 1
useOpenCL: 1
isGPUCapable: 1
isGPUAllowed: 1
GPUName: NVIDIA GeForce RTX 4090
GPUVendor: NVIDIA
NVIDIA GeForce RTX 4090 UNKNOWN, NVIDIA
IsNativeGPUCapable: 1
IsOpenCLGPUCapable: 1
HasSufficientRAM: 1
GPU accessible RAM: 24,142 MB
Required GPU accessible RAM: 1,500 MB
UseGraphicsProcessorChecked: 1
UseOpenCLChecked: 1
Windows remote desktop: 0
Windows available feature level: 12.2
Windows required feature level: 12.0
Windows has required feature level: 1
Anzeige: 1
Displaygrenzen: (0, 0) -> (2560, 1440)
Anzeigeskalierung: 1
Hauptanzeige
Anzeigetyp: SDR
Anzeigeprofil: CS2730(32461018)02Adobe RGB
Anzeige: 2
Displaygrenzen: (2560, 0) -> (5120, 1440)
Anzeigetyp: SDR
Anzeigeprofil: PL2791Q #2 2022-03-01 08-00 0.3127x 0.329y sRGB F-S XYZLUT+MTX
------- Sniffer output
[0 ms]
Launch GPUSnifferThread
[0 ms]
Start RunAllAPIs
[0 ms]
C:\Program Files\Adobe\Adobe Photoshop (Beta)\sniffer.exe -baseTimeMS=2830851 -comment=Photoshop Version: Adobe Photoshop 27.0.1 20251006.m.3249 97696d7 x64
[0 ms]
Start GetSnifferResult
[353 ms]
Start sniffer 2025-10-08 07:51:27
# Photoshop Version: Adobe Photoshop 27.0.1 20251006.m.3249 97696d7 x64
{36 ms}
Start platform native
# displays: 2
Display 0
Display: \\.\DISPLAY1
Main: TRUE
Built in: FALSE
Stereo: FALSE
Bounds: (0, 0) -> (2,560, 1,440)
Dimensions: (2,560 1,440)
Display scale: 1
Physical size: (0 0)
Pixel size: (0 0)
Dynamic range: (0 1)
Attached Device: (DeviceID name=NVIDIA GeForce RTX 4090 index=0)
Display 1
Display: \\.\DISPLAY2
Main: FALSE
Built in: FALSE
Stereo: FALSE
Bounds: (2,560, 0) -> (5,120, 1,440)
Display scale: 1
Pixel size: (0 0)
# devices: 1
Device 0
Preferred: TRUE
Power Envelope: UNKNOWN
Attachment: UNKNOWN
# attached displays: 2
\\.\DISPLAY1
\\.\DISPLAY2
VRAM: 24,142 MB
Dedicated System RAM: 0 MB
Shared System RAM: 34,177 MB
API version: 12.2 (12.2)
Device version: 12.0 (12.0)
Vendor name: NVIDIA
Driver date: 2025-09-05 000000.000000-000
Driver age: 1 month
Driver version: 32.0.15.8129
Supports UMA: UNSUPPORTED
D3D-ID: 9860
End platform native
{220 ms}
{220 ms}
Start platform OpenCL
# displays: 0
# devices: 1
Device 0
Preferred: TRUE
Power Envelope: DISCRETE
Attachment: UNKNOWN
# attached displays: 0
GPU accessible RAM: 25,756 MB
VRAM: 25,756 MB
Shared System RAM: 0 MB
API version: 3.0 (OpenCL 3.0 CUDA)
Device version: 3.0 (OpenCL 3.0 CUDA)
Vendor name: NVIDIA
Driver date: UNKNOWN
Driver age: UNKNOWN
Driver version: UNKNOWN
Bandwidth: 2,127 GB / s
Compute score: 34,153
Device name string: NVIDIA GeForce RTX 4090
Device vendor string: NVIDIA Corporation
Platform name string: NVIDIA CUDA
Platform vendor string: NVIDIA Corporation
End platform OpenCL
{315 ms}
Exit code kExitNormal
End sniffer 2025-10-08 07:51:27
[kStatusNormal, kExitNormal]
[353 ms]
Finish RunAllAPIs
[355 ms]
Finish GetSnifferResult
======= GPU
Lizenztyp: Abonnement
Seriennummer: 94070529712825134195
GUIDBucket:
Composite Core GPU (comp_core_gpu): on
Composite Core Threads (MultithreadedCompositing): on
Composite Core UI (CompositingDocumentTabUI): off
Composite Core Feature Prefs (CompCoreFeaturePrefs): off
Anwendungsordner: C:\Program Files\Adobe\Adobe Photoshop (Beta)\
Pfad für temporäre Dateien: C:\Users\PC884~1.MUE\AppData\Local\Temp\
Der virtuelle Speicher von Photoshop hat asynchronen E/A aktiviert
Arbeitsvolume(s):
Start, 1,64 T, 1,25 T frei
Ordner Erforderliche Zusatzmodule: C:\Program Files\Adobe\Adobe Photoshop (Beta)\Required\Plug-ins\
Ordner Primäre Zusatzmodule: C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\
Installierte Komponenten
ACE.dll ACE 2025/09/11-15:51:06 25.GD09.7f8af3f 25.GD09.7f8af3f
act_tracing.dll Adobe Common Toolkit 1.0.68
AdobeLinguistic.dll Adobe Linguistic Library 792708d
AdobeOwl.dll Adobe Owl 5.5.0
AdobePDFL.dll PDFL 2025/09/08-11:05:36 25.GD09.549207f 25.GD09.549207f
AdobePIP.dll Adobe Product Improvement Program 8.2.0.16
AdobeSVGAGM.dll AdobeSVGAGM 25.1.e3adea7 25.1.e3adea7
AdobeXMP.dll Adobe XMP Core 2025/03/06-19:12:03 79.9690a87 79.9690a87
AdobeXMPFiles.dll Adobe XMP Files 2025/03/06-19:12:03 79.9690a87 79.9690a87
AdobeXMPScript.dll Adobe XMP Script 2025/03/06-19:12:03 79.9690a87 79.9690a87
AGM.dll AGM 2025/09/11-15:51:06 25.GD09.7f8af3f 25.GD09.7f8af3f
AID.dll AID DLL 1.0.0.58
AIDE.dll AIDE 2025/09/10-07:04:31 25.1.33cf818 25.1.33cf818
aifm.dll AIFM 1.0 23.68434
AILib.dll Adobe Illustrator 2026 30.0.0
aiport.dll AIPort 1.0 23.68434
ARE.dll ARE 2025/09/11-15:51:06 25.GD09.7f8af3f 25.GD09.7f8af3f
AXE8SharedExpat.dll AXE8SharedExpat 2025/07/15-10:43:45 25.GD07.3038539 25.GD07.3038539
AXEDOMCore.dll AXEDOMCore 2025/07/15-10:43:45 25.GD07.3038539 25.GD07.3038539
BIB.dll BIB 2025/09/11-15:51:06 25.GD09.7f8af3f 25.GD09.7f8af3f
BIBUtils.dll BIBUtils 2025/09/11-15:51:06 25.GD09.7f8af3f 25.GD09.7f8af3f
CoolType.dll CoolType 2025/09/11-15:51:06 25.GD09.7f8af3f 25.GD09.7f8af3f
CRClient.dll Adobe Crash Reporter Client DLL 26.5.0.202506270759_7140322
DirectML.dll DirectML Redistributable Library 1.13.1+240111-2204.1.dml-1.13.9b0890f
dnssd.dll Bonjour 3,0,0,2
dvaaccelerate.dll Adobe DVA 2025 25.2.0
dvaadameve.dll Adobe DVA 2025 25.2.0
dvaappsupport.dll Adobe DVA 2025 25.2.0
dvaaudiodevice.dll Adobe DVA 2025 25.2.0
dvaaudiotoolkit.dll Adobe DVA 2025 25.2.0
dvacore.dll Adobe DVA 2025 25.2.0
dvacrashhandler.dll Adobe DVA 2025 25.2.0
dvaevefactory.dll Adobe DVA 2025 25.2.0
dvamarshal.dll Adobe DVA 2025 25.2.0
dvamediatypes.dll Adobe DVA 2025 25.2.0
dvametadata.dll Adobe DVA 2025 25.2.0
dvametadataapi.dll Adobe DVA 2025 25.2.0
dvametadataUI.dll Adobe DVA 2025 25.2.0
dvanet.dll Adobe DVA 2025 25.2.0
dvaplayer.dll Adobe DVA 2025 25.2.0
dvascripting.dll Adobe DVA 2025 25.2.0
dvastorage.dll Adobe DVA 2025 25.2.0
dvatemporalxmp.dll Adobe DVA 2025 25.2.0
dvatransport.dll Adobe DVA 2025 25.2.0
dvaui.dll Adobe DVA 2025 25.2.0
dvauxphost.dll Adobe DVA 2025 25.2.0
dvauxpui.dll Adobe DVA 2025 25.2.0
dvavulcansupport.dll Adobe DVA 2025 25.2.0
dvaworkspace.dll Adobe DVA 2025 25.2.0
dynamic-torqnative.dll Unified Extensibility Platform uxp-9.0.2-uxp1-e0d9ef0
dynamiclink.dll Adobe DVA 2025 25.2.0
ExtendScript.dll ExtendScript 2022/08/18-12:50:45 82.4 82.4
filterport.dll FilterPort 1.1 BUILDVERSION
icucnv74.dll International Components for Unicode Build 14.0.1.04ee3a5
icuin74.dll International Components for Unicode Build 14.0.1.04ee3a5
icuuc74.dll International Components for Unicode Build 14.0.1.04ee3a5
ippcc.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcck0.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccl9.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccy8.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcore.dll core. Intel(R) Integrated Performance Primitives. Core Library. 2021.6 (r0xbffe3c5b)
ippcv.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvk0.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvl9.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvy8.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippi.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippik0.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippil9.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippiy8.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ipps.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsk0.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsl9.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsy8.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippvm.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmk0.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvml9.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmy8.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
JP2KLib.dll JP2KLib 2025/03/06-19:12:03 79.6311509 79.6311509
libcrypto-3-x64.dll The OpenSSL Toolkit 3.0.16
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler Mainline
libssl-3-x64.dll The OpenSSL Toolkit 3.0.16
LogSession.dll LogSession 8.2.0.16
mediacoreif.dll Adobe DVA 2025 25.2.0
Microsoft.AI.MachineLearning.dll Microsoft® Windows® Operating System 1.17.20240223.4.8f5c79c
mkl_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_core.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_sequential.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
MPS.dll MPS 2025/08/19-12:04:54 25.1.befccb1 25.1.befccb1
onnxruntime.dll Microsoft® Windows® Operating System 1.17.20240223.4.8f5c79c
opencv_world4110.dll OpenCV library 4.11.0
pdfport.dll PDFPort 2020/11/19-11:34:27 79.625377 79.625377
Plugin.dll Adobe Photoshop 2026 27.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 12.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 12.0.0.14
PSCloud.dll 1.0.0.1
PSRes.dll Adobe Photoshop 2026 27.0
PSViews.dll Adobe Photoshop 2026 27.0
ScCore.dll ScCore 2022/08/18-12:50:45 82.4 82.4
SVGRE.dll SVGRE 25.1.68819c6 25.1.68819c6
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler Mainline
VulcanControl.dll Vulcan Application Control Library 7.2.0.34
VulcanMessage5.dll Vulcan Message Library 7.2.0.34
WinRTSupport.dll Adobe Photoshop Windows RT Support 1.0.1.0
Einheitliche Erweiterungsplattform uxp-9.0.2-uxp1-e0d9ef0
UPIC 2.6.0
Adaptive Weitwinkelkorrektur 27.0 - aus der Datei "“Adaptive Wide Angle.8bf”"
Aquarell 27.0 - aus der Datei "“Filter Gallery.8bf”"
Basrelief 27.0 - aus der Datei "“Filter Gallery.8bf”"
Bereich 27.0 - aus der Datei "“statistics.8ba”"
Bildpaket-Filter 27.0 - aus der Datei "“ChannelPort.8bf”"
Blendenflecke 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
BMP 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Buntglas-Mosaik 27.0 - aus der Datei "“Filter Gallery.8bf”"
Buntstiftschraffur 27.0 - aus der Datei "“Filter Gallery.8bf”"
Camera Raw 17.5.1 - aus der Datei "“Camera Raw.8bi”"
Camera Raw-Filter 17.5.1 - aus der Datei "“Camera Raw.8bi”"
Chrom 27.0 - aus der Datei "“Filter Gallery.8bf”"
Cineon 27.0 - aus der Datei "“Cineon.8bi”"
Color Lookup-Raster rendern 27.0 - aus der Datei "“Export3DLUT.8be”"
Color Lookup-Tabellen exportieren 27.0 - aus der Datei "“Export3DLUT.8be”"
Conté-Stifte 27.0 - aus der Datei "“Filter Gallery.8bf”"
De-Interlace 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Diagonal verwischen 27.0 - aus der Datei "“Filter Gallery.8bf”"
Dicom 27.0 - aus der Datei "“Dicom.8bi”"
Differenz-Wolken 27.0 - aus der Datei "“Clouds.8bf”"
Distorsion 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Dunkle Malstriche 27.0 - aus der Datei "“Filter Gallery.8bf”"
Durchschnitt 27.0 - aus der Datei "“Average.8bf”"
Entropie 27.0 - aus der Datei "“statistics.8ba”"
Erfassungsbereich 27.0 - aus der Datei "“MeasurementCore.8me”"
Extrudieren 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Farbpapier-Collage 27.0 - aus der Datei "“Filter Gallery.8bf”"
Farbraster 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Fasern 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
FastCore-Routinen 27.0 - aus der Datei "“FastCore.8bx”"
Feuchtes Papier 27.0 - aus der Datei "“Filter Gallery.8bf”"
Filtergalerie 27.0 - aus der Datei "“Filter Gallery.8bf”"
Fluchtpunkt 27.0 - aus der Datei "“VanishingPoint.8bf”"
Fotokopie 27.0 - aus der Datei "“Filter Gallery.8bf”"
Fotos freistellen und gerade ausrichten (Filter) 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Fotos freistellen und gerade ausrichten 27.0 - aus der Datei "“CropPhotosAuto.8li”"
Fresko 27.0 - aus der Datei "“Filter Gallery.8bf”"
Für Web speichern 27.0 - aus der Datei "“Save for Web.8be”"
Für WebDriver speichern 27.0 - aus der Datei "“Save for Web Drover.8be”"
Gekreuzte Malstriche 27.0 - aus der Datei "“Filter Gallery.8bf”"
Gerissene Kanten 27.0 - aus der Datei "“Filter Gallery.8bf”"
Glas 27.0 - aus der Datei "“Filter Gallery.8bf”"
Grobe Malerei 27.0 - aus der Datei "“Filter Gallery.8bf”"
Grobes Pastell 27.0 - aus der Datei "“Filter Gallery.8bf”"
Halide Bottlenecks 27.0 - aus der Datei "“HalideBottlenecks.8bx”"
HDRMergeUI 27.0 - aus der Datei "“HDRMergeUI.8bf”"
HSB/HSL 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
IFF-Format 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
JPEG 2000 27.0 - aus der Datei "“JPEG2000.8bi”"
Kacheleffekt 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Kacheln 27.0 - aus der Datei "“Filter Gallery.8bf”"
Kanten betonen 27.0 - aus der Datei "“Filter Gallery.8bf”"
Kohleumsetzung 27.0 - aus der Datei "“Filter Gallery.8bf”"
Konturen mit Tinte nachzeichnen 27.0 - aus der Datei "“Filter Gallery.8bf”"
Körnung && Aufhellung 27.0 - aus der Datei "“Filter Gallery.8bf”"
Körnung 27.0 - aus der Datei "“Filter Gallery.8bf”"
Kräuseln 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Kreide && Kohle 27.0 - aus der Datei "“Filter Gallery.8bf”"
Kreuzschraffur 27.0 - aus der Datei "“Filter Gallery.8bf”"
Kristallisieren 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Kunststofffolie 27.0 - aus der Datei "“Filter Gallery.8bf”"
Kurtosis 27.0 - aus der Datei "“statistics.8ba”"
Leuchtende Konturen 27.0 - aus der Datei "“Filter Gallery.8bf”"
Malgrund 27.0 - aus der Datei "“Filter Gallery.8bf”"
Malmesser 27.0 - aus der Datei "“Filter Gallery.8bf”"
Matlab-Vorgang 27.0 - aus der Datei "“ChannelPort.8bf”"
Maximum 27.0 - aus der Datei "“statistics.8ba”"
Median 27.0 - aus der Datei "“statistics.8ba”"
Mehrprozessorunterstützung 27.0 - aus der Datei "“MultiProcessor Support.8bx”"
Mezzotint 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Minimum 27.0 - aus der Datei "“statistics.8ba”"
Mit Struktur versehen 27.0 - aus der Datei "“Filter Gallery.8bf”"
Mittelwert 27.0 - aus der Datei "“statistics.8ba”"
MMXCore-Routinen 27.0 - aus der Datei "“MMXCore.8bx”"
Neigung 27.0 - aus der Datei "“statistics.8ba”"
Neonschein 27.0 - aus der Datei "“Filter Gallery.8bf”"
NTSC-Farben 27.0 - aus der Datei "“NTSC Colors.8bf”"
Objektivkorrektur 27.0 - aus der Datei "“Lens Correction.8bf”"
Objektivunschärfe 27.0 - aus der Datei "“Lens Blur.8bf”"
Ölfarbe getupft 27.0 - aus der Datei "“Filter Gallery.8bf”"
OpenEXR 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Ozeanwellen 27.0 - aus der Datei "“Filter Gallery.8bf”"
Parametric Filter NO VERSION - aus der Datei "“MaterialFilter.8bf”"
Patchwork 27.0 - aus der Datei "“Filter Gallery.8bf”"
PCX 27.0 - aus der Datei "“PCX.8bi”"
Pfade -> Illustrator 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Pixar 27.0 - aus der Datei "“Pixar.8bi”"
Polarkoordinaten 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Portable Bit Map 27.0 - aus der Datei "“PBM.8bi”"
Prägepapier 27.0 - aus der Datei "“Filter Gallery.8bf”"
Punktieren 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Punktierstich 27.0 - aus der Datei "“Filter Gallery.8bf”"
Radialer Weichzeichner 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Radiance 27.0 - aus der Datei "“Radiance.8bi”"
Rasterungseffekt 27.0 - aus der Datei "“Filter Gallery.8bf”"
Risse 27.0 - aus der Datei "“Filter Gallery.8bf”"
Schwamm 27.0 - aus der Datei "“Filter Gallery.8bf”"
Schwingungen 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Selektiver Weichzeichner 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Solarisation 27.0 - aus der Datei "“Solarize.8bf”"
SP Substance Suite NO VERSION - aus der Datei "“MaterialSuite.8li”"
Spritzer 27.0 - aus der Datei "“Filter Gallery.8bf”"
Standardabweichung 27.0 - aus der Datei "“statistics.8ba”"
Stempel 27.0 - aus der Datei "“Filter Gallery.8bf”"
Strichumsetzung 27.0 - aus der Datei "“Filter Gallery.8bf”"
Strudel 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Stuck 27.0 - aus der Datei "“Filter Gallery.8bf”"
Substance 3D Viewer NO VERSION - aus der Datei "“Substance3DViewerForPs.8bi”"
Sumi-e 27.0 - aus der Datei "“Filter Gallery.8bf”"
Summe 27.0 - aus der Datei "“statistics.8ba”"
Targa 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Tontrennung && Kantenbetonung 27.0 - aus der Datei "“Filter Gallery.8bf”"
Topaz Gigapixel NO VERSION - aus der Datei "“TopazGigapixelAutomate.8bi”"
Topaz Photo NO VERSION - aus der Datei "“TopazPhoto.8bf”"
Topaz Photo NO VERSION - aus der Datei "“TopazPhotoAutomate.8bi”"
TopazGigapixelApplyImageDataFilter NO VERSION - aus der Datei "“TopazGigapixelApply.8bf”"
TopazGigapixelGatherImageDataFilter NO VERSION - aus der Datei "“TopazGigapixelGather.8bf”"
TopazPhotoApplyImageDataFilter NO VERSION - aus der Datei "“TopazPhotoApply.8bf”"
TopazPhotoGatherImageDataFilter NO VERSION - aus der Datei "“TopazPhotoGather.8bf”"
Unterstützung für Skripten 27.0 - aus der Datei "“ScriptingSupport.8li”"
Varianz 27.0 - aus der Datei "“statistics.8ba”"
Verbiegen 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Verflüssigen 27.0 - aus der Datei "“Liquify.8bf”"
Versetzen 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Verwackelte Striche 27.0 - aus der Datei "“Filter Gallery.8bf”"
Weiches Licht 27.0 - aus der Datei "“Filter Gallery.8bf”"
Wellen 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
WIA-Unterstützung 27.0 - aus der Datei "“WIASupport.8li”"
Windeffekt 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Wireless Bitmap 27.0 - aus der Datei "“WBMP.8bi”"
Wölben 27.0 - aus der Datei "“Standard MultiPlugin.8bf”"
Optionale und Drittanbieter-Plug-ins: KEINE
Doppelte und deaktivierte Zusatzmodule:
Topaz Gigapixel NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazGigapixelAutomate.8bi”"
Topaz Photo NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhoto.8bf”"
Topaz Photo NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAutomate.8bi”"
TopazGigapixelApplyImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazGigapixelApply.8bf”"
TopazGigapixelGatherImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazGigapixelGather.8bf”"
TopazPhotoApplyImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoApply.8bf”"
TopazPhotoGatherImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoGather.8bf”"
Nicht geladene Zusatzmodule: KEINE
Einheitliche Erweiterungsplattform - Erweiterungen:
Home Screen (Geladen) 10.2.0.30 - von der Datei "Erforderlicher Ordner"
CmdN: 1.27.12
FMS: 1.11.5
UAM: 1.5.0
UAB: 2.18.0-17
UAB4: 5.47.0
AXT: 1.0.5
Geladen nach: 100 ms – Einfluss auf die Startzeit: 0 ms
ccx-timeline (Vorbereitet) 3.1.12.0 - von der Datei "Erforderlicher Ordner"
CCX Commenting UXP Webview (Geladen) 30.20.1.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 4084 ms – Einfluss auf die Startzeit: 0 ms
Beta Feedback (Vorbereitet) 1.15.5.0 - von der Datei "Erforderlicher Ordner"
CCX Sharesheet UXP (Vorbereitet) 30.31.8.0 - von der Datei "Erforderlicher Ordner"
CC Libraries Panel (Vorbereitet) 4.12.60.0 - von der Datei "C:\Program Files\Common Files\Adobe/CEP/Extensions\CC_LIBRARIES_PANEL_EXTENSION_4_12_60\"
CAPTURE: 2.0.41 STOCK: 4.2.7
Photoshop Facepile (Geladen) 1.9.0.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 103 ms – Einfluss auf die Startzeit: 0 ms
Share Panel (Geladen) 1.0.24.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 104 ms – Einfluss auf die Startzeit: 0 ms
In app notifications (Geladen) 10.0.113.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 105 ms – Einfluss auf die Startzeit: 0 ms
Retouch Ninja (Vorbereitet) 3.0.47.0 - von der Datei "Plugin Marketplace"
TK Luminosity Mask (Vorbereitet) 1.6.0.0 - von der Datei "Plugin Marketplace"
Content Credentials (Geladen) 0.51.4.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 3226 ms – Einfluss auf die Startzeit: 0 ms
Parametrischer Filter (Vorbereitet) 1.0.0.0 - von der Datei "Erforderlicher Ordner"
Photoshop Adjustments Panel (Geladen) 2.3.12.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 2668 ms – Einfluss auf die Startzeit: 0 ms
Photoshop UXP Export-As (Vorbereitet) 5.12.8.0 - von der Datei "Erforderlicher Ordner"
Photoshop In App Messaging (Geladen) 4.8.8.0 - von der Datei "Erforderlicher Ordner"
Information Alert (Vorbereitet) 0.5.0.0 - von der Datei "Erforderlicher Ordner"
Photoshop Selection Feedback (Vorbereitet) 0.5.0.0 - von der Datei "Erforderlicher Ordner"
Plugins Panel (Vorbereitet) 1.6.9.0 - von der Datei "Erforderlicher Ordner"
Substance 3D Viewer Plugin for Photoshop (Vorbereitet) 1.0.0.0 - von der Datei "C:\Program Files\Common Files\Adobe/UXP/Extensions\com.adobe.substance-3d.viewer.ps\"
IC popup message (Geladen) 1.0.0.0
Geladen nach: 3195 ms – Einfluss auf die Startzeit: 0 ms
Multilayer Protection (Geladen) 1.0.0.0
Discover Panel (Geladen) 2509.132.0.11 - von der Datei "Erforderlicher Ordner"
Geladen nach: 4108 ms – Einfluss auf die Startzeit: 0 ms
Neural Filters (Eingetragen) 1.15.0.102 - von der Datei "Erforderlicher Ordner"
Scanzeit: 1 ms – Einträge: 40
Erweiterungen:
com.adobe.stock.panel.licensing-embedded 4.0.35 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_12_60\extensions\stock-panel-licensing\index.html”
com.adobe.capture.extension 2.0.41 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_12_60\extensions\capture\capture.html”
Exportieren als 4.8.16 – aus der Datei “C:\Program Files\Adobe\Adobe Photoshop (Beta)\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
com.adobe.cclibraries.manager 1.0.0 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_12_60\manager.html”
Logi Options+ v1.92.719754.0 7.0.0 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\LogiOptionsPlusAdobe\index.html”
Installierte TWAIN-Geräte: KEINE
Jun 2, 2025 8:35 PM UTC
Hello
After many updates of Photoshop and Photoshop beta, and updates of the NVidia drivers too, the 'banding' problem is still here.
No banding is shown when the image is loaded with the camera raw filter...
Thanks
May 5, 2025 8:07 AM UTC
Hello !
I have the same problem. Banding in Photoshop normal and beta. Both up to date. No banding in the same image in Camera raw filter.
Ryzen 7700X, RTX 3090, Eizo CS 2731.
Here is my SystemInfo :
Version Adobe Photoshop : 26.6.0 20250414.r.14 f1f3569 x64
Nombre de lancements : 12
Système d'exploitation : Windows 11 64 bits
Version : 11 ou version supérieure 10.0.26100.3775
Architecture système : UC AMD Famille :15, modèle :1, niveau :2, AVX2, AVX-512
Nombre de processeurs physiques : 8
Vitesse du processeur : 4500 MHz
Mémoire intégrée : 65130 Mo
Mémoire libre : 41771 Mo
Mémoire disponible pour Photoshop : 51080 Mo
Mémoire utilisée par Photoshop : 70 %
Gestionnaire d'incidents : Adobe
DCX Version: 8.20.0
SAM SDK Version: 12.1.1
ACP.local Status:
- SDK Version: 5.3.0
- Core Sync Running: 7.4.0.31
Version SDK Live Edit client : v5.0.0-beta.11
Adobe Firefly : veuillez utiliser n’importe quelle fonctionnalité d’IA générative pour afficher la dernière version.
Version OpenColorIO : 2.4.0
Version de la bibliothèque C2PA : adobe_c2pa/0.14.2 c2pa-rs/0.43.0
Version NGL : 1.40.0.10
Tableau noir : Désactivé.
Création d’un document de tableau noir : Désactivé.
Rendu D3D12Warp : Désactivé.
Gestion précise des couleurs pour affichage HDR : Activé.
Calques d'alias : Désactivé.
Highbeam: Activé.
Taille de la mosaïque d'images : 1028K
Niveaux de mémoire cache de l'image : 4
Aperçu de la police : Grande
Version d'HarfBuzz : 8.4.0
TextEngine : moteur de texte unifié
======= GPU
API native stable : Vrai
API OpenCL stable : Vrai
GPUDeny: 0
GPUForce: 0
useGPU: 1
useOpenCL: 1
isGPUCapable: 1
isGPUAllowed: 1
GPUName: NVIDIA GeForce RTX 3090
GPUVendor: NVIDIA
NVIDIA GeForce RTX 3090 UNKNOWN, NVIDIA
HasSufficientRAM: 1
GPU accessible RAM: 24,326 MB
UseOpenCLChecked: 1
Affichage : 1
Limites d’affichage : (0, 0) -> (2560, 1440)
Échelle d’affichage : 1
Affichage principal
Type d’affichage : SDR
Profil d’affichage : CS2731(46010092)0491cd_6000K 2.2
Affichage : 2
Limites d’affichage : (2560, 0) -> (5120, 1440)
Profil d’affichage : Q27G2SG4_02-01-2024_centre.icm
Affichage : 3
Limites d’affichage : (5120, 0) -> (7680, 1440)
Profil d’affichage : Q27G2SG4(3)_02-01-2024_droite.icm
Affichage : 4
Limites d’affichage : (7680, 0) -> (10240, 1440)
[0 ms]
[1 ms]
Start RunAllAPIs
[1 ms]
C:\Program Files\Adobe\Adobe Photoshop 2025\sniffer.exe -baseTimeMS=397509 -comment=Photoshop Version: Adobe Photoshop 26.6.0 20250414.r.14 f1f3569 x64
[1 ms]
[613 ms]
Start sniffer 2025-05-05 09:59:26
# Photoshop Version: Adobe Photoshop 26.6.0 20250414.r.14 f1f3569 x64
{52 ms}
# displays: 4
Display 0
Main: TRUE
Built in: FALSE
Stereo: FALSE
Display scale: 1
Pixel size: (0 0)
Attached Device: (DeviceID name=NVIDIA GeForce RTX 3090 index=0)
Display 1
Main: FALSE
Built in: FALSE
Stereo: FALSE
Display scale: 1
Pixel size: (0 0)
Display 2
Display: \\.\DISPLAY3
Main: FALSE
Built in: FALSE
Stereo: FALSE
Bounds: (5,120, 0) -> (7,680, 1,440)
Display scale: 1
Pixel size: (0 0)
Display 3
Display: \\.\DISPLAY4
Main: FALSE
Built in: FALSE
Stereo: FALSE
Bounds: (7,680, 0) -> (10,240, 1,440)
Display scale: 1
Pixel size: (0 0)
# devices: 1
Device 0
Preferred: TRUE
Attachment: UNKNOWN
# attached displays: 4
\\.\DISPLAY1
\\.\DISPLAY2
\\.\DISPLAY3
\\.\DISPLAY4
VRAM: 24,326 MB
Shared System RAM: 34,146 MB
Vendor name: NVIDIA
Driver date: 2025-04-12 000000.000000-000
Driver age: 1 month
Driver version: 32.0.15.7602
D3D-ID: 8708
End platform native
{321 ms}
{321 ms}
# displays: 0
# devices: 1
Device 0
Preferred: TRUE
Attachment: UNKNOWN
GPU accessible RAM: 25,769 MB
VRAM: 25,769 MB
Vendor name: NVIDIA
Driver age: UNKNOWN
Bandwidth: 744 GB / s
Compute score: 15,288.6
Device name string: NVIDIA GeForce RTX 3090
End platform OpenCL
{543 ms}
End sniffer 2025-05-05 09:59:27
[613 ms]
Finish RunAllAPIs
[616 ms]
======= GPU
Type de licence : Abonnement
Numéro de série : 90970338300352604758
GUIDBucket:
Dossier de l'application : C:\Program Files\Adobe\Adobe Photoshop 2025\
Chemin des fichiers temporaires : C:\Users\PC\AppData\Local\Temp\
Le disque de travail de Photoshop comporte l'E/S asynchrone activé.
Volume(s) de travail :
Démarrage, 446,3 Go, 39,1 Go libres
Dossier des modules externes requis : C:\Program Files\Adobe\Adobe Photoshop 2025\Required\Plug-ins\
Dossier des modules externes principaux : C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\
Composants installés :
ACE.dll ACE 2025/03/11-13:46:07 79.ffa7413 79.ffa7413
act_tracing.dll Copyright (c) 2021 Adobe. All Rights Reserved 1.0.58
AdobeLinguistic.dll Adobe Linguistic Library 1d87f11
AdobePDFL.dll PDFL 2025/03/11-13:46:07 79.3325af6 79.3325af6
AdobeSVGAGM.dll AdobeSVGAGM 79.6336193 79.6336193
AGM.dll AGM 2025/03/11-13:46:07 79.ffa7413 79.ffa7413
AIDE.dll AIDE 2025/03/11-10:42:09 79.0edcdaa 79.0edcdaa
AILib.dll Adobe Illustrator 2024 29.0.0
ARE.dll ARE 2025/03/11-13:46:07 79.ffa7413 79.ffa7413
AXE8SharedExpat.dll AXE8SharedExpat 2025/03/06-19:12:03 79.4abff3a 79.4abff3a
AXEDOMCore.dll AXEDOMCore 2025/03/06-19:12:03 79.4abff3a 79.4abff3a
BIB.dll BIB 2025/03/11-13:46:07 79.ffa7413 79.ffa7413
BIBUtils.dll BIBUtils 2025/03/11-13:46:07 79.ffa7413 79.ffa7413
CoolType.dll CoolType 2025/03/11-13:46:07 79.ffa7413 79.ffa7413
CRClient.dll Adobe Crash Reporter Client DLL 16.7.0.202408221003_c7c60a5
dvaaudiodsp.dll Adobe DVA 2024 24.2.0
dvaeve.dll Adobe DVA 2024 24.2.0
dvatexteditor.dll Adobe DVA 2024 24.2.0
dynamic-torqnative.dll Unified Extensibility Platform uxp-8.1.2-0-091bd7d
filterport.dll FilterPort 1.1 O
libcrypto-3-x64.dll The OpenSSL Toolkit 3.0.14
libeay32.dll The OpenSSL Toolkit 1.0.2zg
libssl-3-x64.dll The OpenSSL Toolkit 3.0.14
MPS.dll MPS 2025/03/11-13:46:07 79.a22178b 79.a22178b
opencv_world452.dll OpenCV library 4.5.2
Plugin.dll Adobe Photoshop 2025 26.6
PSCloud.dll 1.0.0.1
PSRes.dll Adobe Photoshop 2025 26.6
PSViews.dll Adobe Photoshop 2025 26.6
ssleay32.dll The OpenSSL Toolkit 1.0.2zg
SVGRE.dll SVGRE 79.5724c48 79.5724c48
WRServices.dll WRServices Build 19.0.0.229b8f9 19.0.0.229b8f9
Plate-forme d'extensibilité unifiée uxp-8.1.2-0-091bd7d
UPIC 2.6.0
Modules externes requis :
Aérographe 26.6 - du fichier “Filter Gallery.8bf”
AlphaLaplacianEnhance NO VERSION - du fichier “AlphaLaplacianEnhanced64.8bf”
Aplatissement 26.6 - du fichier “statistics.8ba”
Aquarelle 26.6 - du fichier “Filter Gallery.8bf”
Asymétrie 26.6 - du fichier “statistics.8ba”
Barbouillage 26.6 - du fichier “Filter Gallery.8bf”
Bas-relief 26.6 - du fichier “Filter Gallery.8bf”
BMP 26.6 - du fichier “Standard MultiPlugin.8bf”
Camera Raw 17.3 - du fichier “Camera Raw.8bi”
Carrelage 26.6 - du fichier “Standard MultiPlugin.8bf”
Chrome 26.6 - du fichier “Filter Gallery.8bf”
Cineon 26.6 - du fichier “Cineon.8bi”
Cisaillement 26.6 - du fichier “Standard MultiPlugin.8bf”
Contour accentué 26.6 - du fichier “Filter Gallery.8bf”
Contour déchiré 26.6 - du fichier “Filter Gallery.8bf”
Contour encré 26.6 - du fichier “Filter Gallery.8bf”
Contour lumineux 26.6 - du fichier “Filter Gallery.8bf”
Contour postérisé 26.6 - du fichier “Filter Gallery.8bf”
Contraction 26.6 - du fichier “Standard MultiPlugin.8bf”
Coordonnées polaires 26.6 - du fichier “Standard MultiPlugin.8bf”
Correction de l'objectif 26.6 - du fichier “Lens Correction.8bf”
Couleurs NTSC 26.6 - du fichier “NTSC Colors.8bf”
Couteau à palette 26.6 - du fichier “Filter Gallery.8bf”
Craie/Fusain 26.6 - du fichier “Filter Gallery.8bf”
Craquelure 26.6 - du fichier “Filter Gallery.8bf”
Crayon Conté 26.6 - du fichier “Filter Gallery.8bf”
Crayon de couleur 26.6 - du fichier “Filter Gallery.8bf”
Cristallisation 26.6 - du fichier “Standard MultiPlugin.8bf”
Croisillons 26.6 - du fichier “Filter Gallery.8bf”
Découpage 26.6 - du fichier “Filter Gallery.8bf”
Demi-teintes couleur 26.6 - du fichier “Standard MultiPlugin.8bf”
Désentrelacement 26.6 - du fichier “Standard MultiPlugin.8bf”
Diagonales 26.6 - du fichier “Filter Gallery.8bf”
Dicom 26.6 - du fichier “Dicom.8bi”
Dispersion 26.6 - du fichier “Standard MultiPlugin.8bf”
Ecart type 26.6 - du fichier “statistics.8ba”
Effet mosaïque 26.6 - du fichier “Filter Gallery.8bf”
Effet pointilliste 26.6 - du fichier “Filter Gallery.8bf”
Emballage plastique 26.6 - du fichier “Filter Gallery.8bf”
Enregistrer pour le Web 26.6 - du fichier “Save for Web.8be”
Entropie 26.6 - du fichier “statistics.8ba”
Eponge 26.6 - du fichier “Filter Gallery.8bf”
Epson Print Layout 1.0 - du fichier “Epson Print Layout.8li”
Etalement 26.6 - du fichier “Filter Gallery.8bf”
Exporter les tables de correspondance de couleur 26.6 - du fichier “Export3DLUT.8be”
Extension WIA 26.6 - du fichier “WIASupport.8li”
Extrusion 26.6 - du fichier “Standard MultiPlugin.8bf”
Fibres 26.6 - du fichier “Standard MultiPlugin.8bf”
Filtre Camera Raw 17.3 - du fichier “Camera Raw.8bi”
Filtre Collection d'images 26.6 - du fichier “ChannelPort.8bf”
Filtre Rogner et désincliner les photos 26.6 - du fichier “Standard MultiPlugin.8bf”
Flou de l'objectif 26.6 - du fichier “Lens Blur.8bf”
Flou optimisé 26.6 - du fichier “Standard MultiPlugin.8bf”
Flou radial 26.6 - du fichier “Standard MultiPlugin.8bf”
Fluidité 26.6 - du fichier “Liquify.8bf”
Format IFF 26.6 - du fichier “Standard MultiPlugin.8bf”
Fresque 26.6 - du fichier “Filter Gallery.8bf”
Galerie de filtres 26.6 - du fichier “Filter Gallery.8bf”
GigapixelApplyImageDataFilter NO VERSION - du fichier “TopazGigapixelAIApply.8bf”
Grain 26.6 - du fichier “Filter Gallery.8bf”
Grain photo 26.6 - du fichier “Filter Gallery.8bf”
Grand-angle adaptatif 26.6 - du fichier “Adaptive Wide Angle.8bf”
Halide Bottlenecks 26.6 - du fichier “HalideBottlenecks.8bx”
Halo 26.6 - du fichier “Standard MultiPlugin.8bf”
HDRMergeUI 26.6 - du fichier “HDRMergeUI.8bf”
JPEG 2000 26.6 - du fichier “JPEG2000.8bi”
Lueur diffuse 26.6 - du fichier “Filter Gallery.8bf”
Matlab Operation 26.6 - du fichier “ChannelPort.8bf”
Maximum 26.6 - du fichier “statistics.8ba”
Médiane 26.6 - du fichier “statistics.8ba”
Merge to Nik 6 HDR Efex NO VERSION - du fichier “Nik6HDRMerge.8li”
Mezzo-tinto 26.6 - du fichier “Standard MultiPlugin.8bf”
Minimum 26.6 - du fichier “statistics.8ba”
Motif de demi-teintes 26.6 - du fichier “Filter Gallery.8bf”
Moyenne 26.6 - du fichier “Average.8bf”
Moyenne arithmétique 26.6 - du fichier “statistics.8ba”
Multiprocesseur 26.6 - du fichier “MultiProcessor Support.8bx”
Néon 26.6 - du fichier “Filter Gallery.8bf”
Nik 6 Analog Efex NO VERSION - du fichier “NikCollection.8bf”
Nik 6 Color Efex NO VERSION - du fichier “NikCollection.8bf”
Nik 6 Dfine NO VERSION - du fichier “NikCollection.8bf”
Nik 6 HDR Efex NO VERSION - du fichier “NikCollection.8bf”
Nik 6 Perspective 6.13.0.2 - du fichier “PhotoshopPlugin-filterNik 6 Perspective64.8bf”
Nik 6 Perspective automation 6.13.0.2 - du fichier “PhotoshopPlugin-automationNik 6 Perspective64.8li”
Nik 6 Presharpener NO VERSION - du fichier “NikCollection.8bf”
Nik 6 PresharpenerNik Collection 6stub NO VERSION - du fichier “NikCollection.8bf”
Nik 6 Sharpener Output NO VERSION - du fichier “NikCollection.8bf”
Nik 6 Silver Efex NO VERSION - du fichier “NikCollection.8bf”
Nik 6 Viveza NO VERSION - du fichier “NikCollection.8bf”
Nik Collection 6 Palette 6.13.0.2 - du fichier “Nik Collection 6 Palette.8li”
Nik Collection Service NO VERSION - du fichier “NikCollection.8bf”
Nik6BackgroundFilter NO VERSION - du fichier “Nik6BackgroundFilter.8bf”
Nik6FineStructuresFilter NO VERSION - du fichier “Nik6FineStructuresFilter.8bf”
Nik6HotPixelsFilter NO VERSION - du fichier “Nik6HotPixelsFilter.8bf”
Nik6ShadowsFilter NO VERSION - du fichier “Nik6ShadowsFilter.8bf”
Nik6SkinFilter NO VERSION - du fichier “Nik6SkinFilter.8bf”
Nik6SkyFilter NO VERSION - du fichier “Nik6SkyFilter.8bf”
Nik6StrongNoiseFilter NO VERSION - du fichier “Nik6StrongNoiseFilter.8bf”
Noir/Blanc 26.6 - du fichier “Filter Gallery.8bf”
Noyau de mesures 26.6 - du fichier “MeasurementCore.8me”
Nuages 26.6 - du fichier “Clouds.8bf”
Nuages par différence 26.6 - du fichier “Clouds.8bf”
Océan 26.6 - du fichier “Filter Gallery.8bf”
Onde 26.6 - du fichier “Standard MultiPlugin.8bf”
Ondulation 26.6 - du fichier “Standard MultiPlugin.8bf”
OpenEXR 26.6 - du fichier “Standard MultiPlugin.8bf”
Papier gaufré 26.6 - du fichier “Filter Gallery.8bf”
Papier humide 26.6 - du fichier “Filter Gallery.8bf”
Parametric Filter NO VERSION - du fichier “MaterialFilter.8bf”
Pastels 26.6 - du fichier “Filter Gallery.8bf”
Patchwork 26.6 - du fichier “Filter Gallery.8bf”
PCX 26.6 - du fichier “PCX.8bi”
Photocopie 26.6 - du fichier “Filter Gallery.8bf”
Pinceau à sec 26.6 - du fichier “Filter Gallery.8bf”
Pixar 26.6 - du fichier “Pixar.8bi”
Placage de texture 26.6 - du fichier “Filter Gallery.8bf”
Plâtre 26.6 - du fichier “Filter Gallery.8bf”
Plume calligraphique 26.6 - du fichier “Filter Gallery.8bf”
Point de fuite 26.6 - du fichier “VanishingPoint.8bf”
Pointillisme 26.6 - du fichier “Standard MultiPlugin.8bf”
Portable Bit Map 26.6 - du fichier “PBM.8bi”
Portée 26.6 - du fichier “statistics.8ba”
Radiance 26.6 - du fichier “Radiance.8bi”
Rendu de la grille de correspondance de couleur 26.6 - du fichier “Export3DLUT.8be”
Réticulation 26.6 - du fichier “Filter Gallery.8bf”
Retouch4me Frequency Separation 1.0 - du fichier “Retouch4me Frequency Separation.8bf”
Retouch4me FS Automation 1.0 - du fichier “Retouch4me FS Automation.8li”
Rogner et désincliner les photos 26.6 - du fichier “CropPhotosAuto.8li”
Routines FastCore 26.6 - du fichier “FastCore.8bx”
Routines MMXCore 26.6 - du fichier “MMXCore.8bx”
Service Nik 6 HDR Efex Filter NO VERSION - du fichier “NikCollection.8bf”
Solarisation 26.6 - du fichier “Solarize.8bf”
Sommation 26.6 - du fichier “statistics.8ba”
Soufflerie 26.6 - du fichier “Standard MultiPlugin.8bf”
Sous-couche 26.6 - du fichier “Filter Gallery.8bf”
SP Substance Suite NO VERSION - du fichier “MaterialSuite.8li”
Sphérisation 26.6 - du fichier “Standard MultiPlugin.8bf”
Substance 3D Viewer NO VERSION - du fichier “Substance3DViewerForPs.8bi”
Sumi-e 26.6 - du fichier “Filter Gallery.8bf”
Support de script 26.6 - du fichier “ScriptingSupport.8li”
Tampon 26.6 - du fichier “Filter Gallery.8bf”
Targa 26.6 - du fichier “Standard MultiPlugin.8bf”
Topaz Gigapixel AI NO VERSION - du fichier “TopazGigapixelAIAutomate.8bi”
Tourbillon 26.6 - du fichier “Standard MultiPlugin.8bf”
Tracés vers Illustrator 26.6 - du fichier “Standard MultiPlugin.8bf”
TSL/TSI 26.6 - du fichier “Standard MultiPlugin.8bf”
Variance 26.6 - du fichier “statistics.8ba”
Verre 26.6 - du fichier “Filter Gallery.8bf”
Vitrail 26.6 - du fichier “Filter Gallery.8bf”
Wireless Bitmap 26.6 - du fichier “WBMP.8bi”
Zigzag 26.6 - du fichier “Standard MultiPlugin.8bf”
Modules externes tiers et facultatifs :
GigapixelGatherImageDataFilter NO VERSION - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\TopazGigapixelAIGather.8bf”
PTLens 9, 0, 0, 33 - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\PTLens64.8BF”
Qimage One Export (Use Automate|Qimage One) NO VERSION - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\Q1Export.x64.8be”
Qimage One NO VERSION - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\Q1Automate.x64.8li”
Qimage Ultimate NO VERSION - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\QUAutomate.8li”
QUExport (Use Automate|Qimage Ultimate) NO VERSION - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\QUExport.8be”
Modules externes en double et désactivés :
GigapixelApplyImageDataFilter NO VERSION - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\TopazGigapixelAIApply.8bf”
GigapixelGatherImageDataFilter NO VERSION - du fichier “TopazGigapixelAIGather.8bf”
Topaz Gigapixel AI NO VERSION - du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\TopazGigapixelAIAutomate.8bi”
Modules externes dont le chargement a échoué : AUCUN
Plate-forme d'extensibilité unifiée - Extensions :
Home Screen (Chargé) 9.0.0.122 - à partir du fichier "C:\Program Files\Common Files\Adobe/UXP/Extensions\com.adobe.ccx.start-9.0.0\"
CmdN: 1.24.7
UAB: 2.18.0-8
UAB4: npm:@ccac/universal-asset-browser@5.9.0
Chargé à : 409 ms - impact du temps de lancement : 47 ms
ccx-timeline (Préparé) 3.1.12.0 - à partir du fichier "Dossier requis"
CCX Commenting UXP Webview (Chargé) 30.7.0.0 - à partir du fichier "Dossier requis"
Chargé à : 6947 ms - impact du temps de lancement : 0 ms
CCX Sharesheet UXP (Préparé) 30.24.0.0 - à partir du fichier "Dossier requis"
In app notifications (Chargé) 2.0.25.0 - à partir du fichier "Dossier requis"
Chargé à : 430 ms - impact du temps de lancement : 0 ms
Content Credentials (Chargé) 0.51.4.0 - à partir du fichier "Dossier requis"
Chargé à : 6324 ms - impact du temps de lancement : 0 ms
CC Libraries Panel (Préparé) 4.10.74.0 - à partir du fichier "C:\Program Files\Common Files\Adobe/CEP/Extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_74\"
CAPTURE: 2.0.41 STOCK: 4.2.6
Filtres paramétriques (Préparé) 1.0.0.0 - à partir du fichier "Dossier requis"
Photoshop Adjustments Panel (Chargé) 2.3.4.0 - à partir du fichier "Dossier requis"
Chargé à : 6948 ms - impact du temps de lancement : 1 ms
Photoshop UXP Export-As (Préparé) 5.12.1.0 - à partir du fichier "Dossier requis"
Photoshop In App Messaging (Chargé) 4.5.10.0 - à partir du fichier "Dossier requis"
Chargé à : 6948 ms - impact du temps de lancement : 0 ms
Information Alert (Préparé) 0.5.0.0 - à partir du fichier "Dossier requis"
Photoshop Selection Feedback (Préparé) 0.5.0.0 - à partir du fichier "Dossier requis"
Share Panel (Préparé) 1.0.12.0 - à partir du fichier "Dossier requis"
Plugins Panel (Préparé) 1.6.9.0 - à partir du fichier "Dossier requis"
Substance 3D Viewer Plugin for Photoshop (Préparé) 1.0.0.0 - à partir du fichier "C:\Program Files\Common Files\Adobe/UXP/Extensions\com.adobe.substance-3d.viewer.ps\"
mobGlow Plugin (Préparé) 1.0.1.0 - à partir du fichier "C:\Program Files\Adobe\Adobe Photoshop 2025\Plug-ins\mobglow.plugin.uxp_PS/"
IC popup message (Chargé) 1.0.0.0
Chargé à : 6325 ms - impact du temps de lancement : 0 ms
Multilayer Protection (Chargé) 1.0.0.0
Chargé à : 6326 ms - impact du temps de lancement : 0 ms
Discover Panel (Chargé) 2503.120.0.14 - à partir du fichier "Dossier requis"
Chargé à : 6949 ms - impact du temps de lancement : 1 ms
Neural Filters (Marque déposée) 1.15.0.102 - à partir du fichier "Dossier requis"
Temps de balayage : 0 ms - entrées : 42
Extensions :
Bibliothèques 1.0.0 - A partir du fichier “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_74\index.html”
com.adobe.stock.panel.licensing-embedded 4.0.35 - A partir du fichier “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_74\extensions\stock-panel-licensing\index.html”
com.adobe.capture.extension 2.0.41 - A partir du fichier “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_74\extensions\capture\capture.html”
Exporter sous 4.8.16 - A partir du fichier “C:\Program Files\Adobe\Adobe Photoshop 2025\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
com.adobe.cclibraries.manager 1.0.0 - A partir du fichier “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_74\manager.html”
Modules TWAIN installés : AUCUN
Thanks
CShubert
Apr 30, 2025 5:51 PM UTC
Thanks everyone. The team will investigate this issue and we will update when we have a solution.
Cory - Photoshop Product Manager
pascalm3859019
Apr 28, 2025 5:03 AM UTC
Yes, there is no change. I´m still having this issue in both versions of Photoshop.
Adobe Photoshop Version: 26.7.0 20250422.m.3052 1f4af87 x64 beta and
Adobe Photoshop Version: 26.6.0 20250414.r.14 f1f3569 x64 standard
I have also updated the Nvidia Studio driver to the latest available 576.02.
CShubert
Apr 25, 2025 2:02 PM UTC
@pascalm3859019 do you still see the same issue with the latest Ps beta?
Adobe Photoshop Version: 26.7.0 20250422.m.3052 1f4af87 arm64
pascalm3859019
Apr 10, 2025 5:08 AM UTC
Hi Cory, please have a look at my first post. There you can find screenshots attached that show this setting and also the described problem in all details.
CShubert
Apr 9, 2025 9:31 PM UTC
Thanks all, could you also share screenshots of your prefs screen that shows this setting?
This is from my Mac, but what is yours showing...
Cory
Apr 9, 2025 8:45 PM UTC
Thanks for replying Cory! I am also seeing this on the release version of PS.
Could it be a driver issue? I use the same driver as @pascalm3859019 mentioned in his post.
Here's my SystemInfo:
Adobe Photoshop Version: 26.6.0 20250406.m.3035 d2362a1 x64
Anzahl der Starts: 146
Version: 11 oder höher 10.0.26100.3775
Systemarchitektur: AMD CPU-Familie:15, Modell:1, Stepping:0, AVX2, Hyper-Threading
Physischer Prozessor: 32
Logischer Prozessor: 64
Prozessor-Taktfrequenz: 3722 MHz
Eingebauter Speicher: 65406 MB
Freier Speicher: 41948 MB
Für Photoshop verfügbarer Arbeitsspeicher: 51301 MB
DCX Version: 8.20.0
ACP.local Status:
Client-SDK-Version für Live-Bearbeitung: v5.0.0-beta.11
OpenColorIO-Version: 2.4.0
NGL-Version: 1.40.0.10
Tafel: Aktiviert.
Spec Version 1.4
Impl Version 1.39
Num Devices 1
Bildcache: 4
Schriftvorschau: Mittel
TextEngine: einheitliches Textmodul
======= GPU
GPUDeny: 0
GPUForce: 0
useGPU: 1
useOpenCL: 1
isGPUCapable: 1
isGPUAllowed: 1
GPUVendor: NVIDIA
HasSufficientRAM: 1
UseOpenCLChecked: 1
Anzeige: 1
Hauptanzeige
Anzeigetyp: SDR
Anzeigeprofil: CG279X(31559109)08Adobe RGB
Anzeige: 2
Anzeigetyp: SDR
Anzeigeprofil: CG277(33029065)02Adobe RGB
[0 ms]
[1 ms]
Start RunAllAPIs
[1 ms]
C:\Program Files\Adobe\Adobe Photoshop (Beta)\sniffer.exe -baseTimeMS=5171674 -comment=Photoshop Version: Adobe Photoshop 26.6.0 20250406.m.3035 d2362a1 x64
[1 ms]
[744 ms]
Start sniffer 2025-04-09 22:30:23
# Photoshop Version: Adobe Photoshop 26.6.0 20250406.m.3035 d2362a1 x64
{90 ms}
# displays: 2
Display 0
Main: TRUE
Built in: FALSE
Stereo: FALSE
Display scale: 1
Pixel size: (0 0)
Display 1
Main: FALSE
Built in: FALSE
Stereo: FALSE
Display scale: 1
Pixel size: (0 0)
# devices: 1
Device 0
Preferred: TRUE
Attachment: UNKNOWN
\\.\DISPLAY1
\\.\DISPLAY2
VRAM: 24,326 MB
Shared System RAM: 34,291 MB
Vendor name: NVIDIA
Driver date: 2025-03-14 000000.000000-000
Driver age: 1 month
Driver version: 32.0.15.7283
D3D-ID: 8708
End platform native
{420 ms}
{420 ms}
# displays: 0
# devices: 1
Device 0
Preferred: TRUE
Attachment: UNKNOWN
VRAM: 25,769 MB
Vendor name: NVIDIA
Driver age: UNKNOWN
Bandwidth: 736 GB / s
Compute score: 10,790.7
End platform OpenCL
{709 ms}
End sniffer 2025-04-09 22:30:24
[744 ms]
Finish RunAllAPIs
[749 ms]
======= GPU
Seriennummer: 90970428036949145266
GUIDBucket:
Pfad für temporäre Dateien: C:\Users\Pascal\AppData\Local\Temp\
Arbeitsvolume(s):
D:\, 500,0 GB, 37,7 GB frei
C:\, 836,8 GB, 360,3 GB frei
ACE.dll ACE 2025/03/04-17:39:58 171.ed70209 171.ed70209
AdobePDFL.dll PDFL 2025/02/14-12:47:25 79.9bd8d90 79.9bd8d90
AdobeXMP.dll Adobe XMP Core 2025/02/11-19:10:08 79.78b7638 79.78b7638
AdobeXMPFiles.dll Adobe XMP Files 2025/02/11-19:10:08 79.78b7638 79.78b7638
AdobeXMPScript.dll Adobe XMP Script 2025/02/11-19:10:08 79.78b7638 79.78b7638
AGM.dll AGM 2025/03/04-17:39:58 171.ed70209 171.ed70209
AIDE.dll AIDE 2025/02/07-19:06:43 79.1b6aebc 79.1b6aebc
ARE.dll ARE 2025/03/04-17:39:58 171.ed70209 171.ed70209
AXE8SharedExpat.dll AXE8SharedExpat 2025/01/14-12:18:39 79.b88f22e 79.b88f22e
AXEDOMCore.dll AXEDOMCore 2025/01/14-12:18:39 79.b88f22e 79.b88f22e
BIB.dll BIB 2025/03/04-17:39:58 171.ed70209 171.ed70209
BIBUtils.dll BIBUtils 2025/03/04-17:39:58 171.ed70209 171.ed70209
CoolType.dll CoolType 2025/03/04-17:39:58 171.ed70209 171.ed70209
JP2KLib.dll JP2KLib 2024/11/13-19:07:24 79.6111b85 79.6111b85
MPS.dll MPS 2025/02/19-17:35:19 79.a6debab 79.a6debab
PSCloud.dll 1.0.0.1
SVGRE.dll SVGRE 79.020f82e 79.020f82e
Einheitliche Erweiterungsplattform uxp-8.1.2-0-091bd7d
UPIC 2.6.0
Adaptive Weitwinkelkorrektur 26.6 - aus der Datei "“Adaptive Wide Angle.8bf”"
Aquarell 26.6 - aus der Datei "“Filter Gallery.8bf”"
Aurora HDR 17.0 - aus der Datei "“AuroraHDR.8bf”"
Basrelief 26.6 - aus der Datei "“Filter Gallery.8bf”"
Bereich 26.6 - aus der Datei "“statistics.8ba”"
Bildpaket-Filter 26.6 - aus der Datei "“ChannelPort.8bf”"
Blendenflecke 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Blow Up 3 3.1.4 - aus der Datei "“Alien Skin Blow Up 3 Automation x64.8li”"
Blow Up 3.1.4 - aus der Datei "“Alien Skin Blow Up 3 Photoshop x64.8bf”"
BMP 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Buntglas-Mosaik 26.6 - aus der Datei "“Filter Gallery.8bf”"
Buntstiftschraffur 26.6 - aus der Datei "“Filter Gallery.8bf”"
Camera Raw 17.2 - aus der Datei "“Camera Raw.8bi”"
Camera Raw-Filter 17.2 - aus der Datei "“Camera Raw.8bi”"
Chrom 26.6 - aus der Datei "“Filter Gallery.8bf”"
Cineon 26.6 - aus der Datei "“Cineon.8bi”"
Color Lookup-Raster rendern 26.6 - aus der Datei "“Export3DLUT.8be”"
Color Lookup-Tabellen exportieren 26.6 - aus der Datei "“Export3DLUT.8be”"
Conté-Stifte 26.6 - aus der Datei "“Filter Gallery.8bf”"
De-Interlace 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Diagonal verwischen 26.6 - aus der Datei "“Filter Gallery.8bf”"
Dicom 26.6 - aus der Datei "“Dicom.8bi”"
Differenz-Wolken 26.6 - aus der Datei "“Clouds.8bf”"
Distorsion 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Dunkle Malstriche 26.6 - aus der Datei "“Filter Gallery.8bf”"
Durchschnitt 26.6 - aus der Datei "“Average.8bf”"
DxO FilmPack 7 7.12.1.2 - aus der Datei "“PhotoshopPlugin-filter64dfpv7.8bf”"
DxO ViewPoint 4 4.22.1.1 - aus der Datei "“PhotoshopPlugin-filterdvpv464.8bf”"
DxO ViewPoint 4 automation 4.22.1.1 - aus der Datei "“PhotoshopPlugin-automationdvpv464.8li”"
Entropie 26.6 - aus der Datei "“statistics.8ba”"
Erfassungsbereich 26.6 - aus der Datei "“MeasurementCore.8me”"
Exposure X7 7.1.5 - aus der Datei "“Exposure Software Exposure X7 Photoshop x64.8bf”"
Exr-IO 2.0 - aus der Datei "“Exr-io.8bi”"
Extrudieren 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Farbpapier-Collage 26.6 - aus der Datei "“Filter Gallery.8bf”"
Farbraster 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Fasern 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
FastCore-Routinen 26.6 - aus der Datei "“FastCore.8bx”"
Feuchtes Papier 26.6 - aus der Datei "“Filter Gallery.8bf”"
Filtergalerie 26.6 - aus der Datei "“Filter Gallery.8bf”"
Fluchtpunkt 26.6 - aus der Datei "“VanishingPoint.8bf”"
Fotokopie 26.6 - aus der Datei "“Filter Gallery.8bf”"
Fotos freistellen und gerade ausrichten (Filter) 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Fotos freistellen und gerade ausrichten 26.6 - aus der Datei "“CropPhotosAuto.8li”"
Fresko 26.6 - aus der Datei "“Filter Gallery.8bf”"
Für Web speichern 26.6 - aus der Datei "“Save for Web.8be”"
Gekreuzte Malstriche 26.6 - aus der Datei "“Filter Gallery.8bf”"
Gerissene Kanten 26.6 - aus der Datei "“Filter Gallery.8bf”"
GigapixelApplyImageDataFilter NO VERSION - aus der Datei "“TopazGigapixelAIApply.8bf”"
GigapixelGatherImageDataFilter NO VERSION - aus der Datei "“TopazGigapixelAIGather.8bf”"
Glas 26.6 - aus der Datei "“Filter Gallery.8bf”"
Grobe Malerei 26.6 - aus der Datei "“Filter Gallery.8bf”"
Grobes Pastell 26.6 - aus der Datei "“Filter Gallery.8bf”"
Halide Bottlenecks 26.6 - aus der Datei "“HalideBottlenecks.8bx”"
HDRMergeUI 26.6 - aus der Datei "“HDRMergeUI.8bf”"
HSB/HSL 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
IFF-Format 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
JPEG 2000 26.6 - aus der Datei "“JPEG2000.8bi”"
Kacheleffekt 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Kacheln 26.6 - aus der Datei "“Filter Gallery.8bf”"
Kanten betonen 26.6 - aus der Datei "“Filter Gallery.8bf”"
Kohleumsetzung 26.6 - aus der Datei "“Filter Gallery.8bf”"
Konturen mit Tinte nachzeichnen 26.6 - aus der Datei "“Filter Gallery.8bf”"
Körnung && Aufhellung 26.6 - aus der Datei "“Filter Gallery.8bf”"
Körnung 26.6 - aus der Datei "“Filter Gallery.8bf”"
Kräuseln 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Kreide && Kohle 26.6 - aus der Datei "“Filter Gallery.8bf”"
Kreuzschraffur 26.6 - aus der Datei "“Filter Gallery.8bf”"
Kristallisieren 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Kunststofffolie 26.6 - aus der Datei "“Filter Gallery.8bf”"
Kurtosis 26.6 - aus der Datei "“statistics.8ba”"
Leuchtende Konturen 26.6 - aus der Datei "“Filter Gallery.8bf”"
Luminar 4 17.0 - aus der Datei "“Luminar4.8bf”"
Luminar AI 17.0 - aus der Datei "“LuminarAI.8bf”"
Luminar Neo 17.0 - aus der Datei "“LuminarNeo.8bf”"
Malgrund 26.6 - aus der Datei "“Filter Gallery.8bf”"
Malmesser 26.6 - aus der Datei "“Filter Gallery.8bf”"
Matlab-Vorgang 26.6 - aus der Datei "“ChannelPort.8bf”"
Maximum 26.6 - aus der Datei "“statistics.8ba”"
Median 26.6 - aus der Datei "“statistics.8ba”"
Mehrprozessorunterstützung 26.6 - aus der Datei "“MultiProcessor Support.8bx”"
Merge to Nik 7 HDR Efex NO VERSION - aus der Datei "“Nik7HDRMerge.8li”"
Mezzotint 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Minimum 26.6 - aus der Datei "“statistics.8ba”"
Mit Struktur versehen 26.6 - aus der Datei "“Filter Gallery.8bf”"
Mittelwert 26.6 - aus der Datei "“statistics.8ba”"
MMXCore-Routinen 26.6 - aus der Datei "“MMXCore.8bx”"
Neigung 26.6 - aus der Datei "“statistics.8ba”"
Neonschein 26.6 - aus der Datei "“Filter Gallery.8bf”"
Nik 7 Analog Efex NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 Color Efex NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 Dfine NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 HDR Efex NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 Presharpener NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 PresharpenerNik Collection 7stub NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 Sharpener Output NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 Silver Efex NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik 7 Viveza NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik Collection 7 Palette 7.0.4.1 - aus der Datei "“Nik Collection 7 Palette.8li”"
Nik Collection Service NO VERSION - aus der Datei "“NikCollection.8bf”"
Nik7BackgroundFilter NO VERSION - aus der Datei "“Nik7BackgroundFilter.8bf”"
Nik7FineStructuresFilter NO VERSION - aus der Datei "“Nik7FineStructuresFilter.8bf”"
Nik7HotPixelsFilter NO VERSION - aus der Datei "“Nik7HotPixelsFilter.8bf”"
Nik7ShadowsFilter NO VERSION - aus der Datei "“Nik7ShadowsFilter.8bf”"
Nik7SkinFilter NO VERSION - aus der Datei "“Nik7SkinFilter.8bf”"
Nik7SkyFilter NO VERSION - aus der Datei "“Nik7SkyFilter.8bf”"
Nik7StrongNoiseFilter NO VERSION - aus der Datei "“Nik7StrongNoiseFilter.8bf”"
NTSC-Farben 26.6 - aus der Datei "“NTSC Colors.8bf”"
Objektivkorrektur 26.6 - aus der Datei "“Lens Correction.8bf”"
Objektivunschärfe 26.6 - aus der Datei "“Lens Blur.8bf”"
Ölfarbe getupft 26.6 - aus der Datei "“Filter Gallery.8bf”"
OpenEXR 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Optics NO VERSION - aus der Datei "“Optics.8bf”"
Ozeanwellen 26.6 - aus der Datei "“Filter Gallery.8bf”"
Patchwork 26.6 - aus der Datei "“Filter Gallery.8bf”"
PCX 26.6 - aus der Datei "“PCX.8bi”"
Pfade -> Illustrator 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Pixar 26.6 - aus der Datei "“Pixar.8bi”"
Polarkoordinaten 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Portable Bit Map 26.6 - aus der Datei "“PBM.8bi”"
PortraitPro 5.0.0 - aus der Datei "“PortraitProPSFilter64.8bf”"
PortraitPro Body 3.1.0 - aus der Datei "“PortraitProBodyPSFilter64.8bf”"
Prägepapier 26.6 - aus der Datei "“Filter Gallery.8bf”"
Punktieren 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Punktierstich 26.6 - aus der Datei "“Filter Gallery.8bf”"
Radialer Weichzeichner 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Radiance 26.6 - aus der Datei "“Radiance.8bi”"
Rasterungseffekt 26.6 - aus der Datei "“Filter Gallery.8bf”"
Risse 26.6 - aus der Datei "“Filter Gallery.8bf”"
Schwamm 26.6 - aus der Datei "“Filter Gallery.8bf”"
Schwingungen 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Selektiver Weichzeichner 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Service Nik 7 HDR Efex Filter NO VERSION - aus der Datei "“NikCollection.8bf”"
Snap Art 4 4.1.3 - aus der Datei "“Alien Skin Snap Art 4 Photoshop x64.8bf”"
Snap Art 4 Autolayer 4.1.3 - aus der Datei "“Alien Skin Snap Art 4 Autolayer x64.8li”"
Solarisation 26.6 - aus der Datei "“Solarize.8bf”"
Spritzer 26.6 - aus der Datei "“Filter Gallery.8bf”"
Standardabweichung 26.6 - aus der Datei "“statistics.8ba”"
Stempel 26.6 - aus der Datei "“Filter Gallery.8bf”"
Strichumsetzung 26.6 - aus der Datei "“Filter Gallery.8bf”"
Strudel 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Stuck 26.6 - aus der Datei "“Filter Gallery.8bf”"
Sumi-e 26.6 - aus der Datei "“Filter Gallery.8bf”"
Summe 26.6 - aus der Datei "“statistics.8ba”"
Targa 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Tontrennung && Kantenbetonung 26.6 - aus der Datei "“Filter Gallery.8bf”"
Topaz Gigapixel AI NO VERSION - aus der Datei "“TopazGigapixelAIAutomate.8bi”"
Topaz Photo AI NO VERSION - aus der Datei "“TopazPhotoAI.8bf”"
TPAIApplyImageDataFilter NO VERSION - aus der Datei "“TopazPhotoAIApply.8bf”"
TPAIGatherImageDataFilter NO VERSION - aus der Datei "“TopazPhotoAIGather.8bf”"
Unterstützung für Skripten 26.6 - aus der Datei "“ScriptingSupport.8li”"
Varianz 26.6 - aus der Datei "“statistics.8ba”"
Verbiegen 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Verflüssigen 26.6 - aus der Datei "“Liquify.8bf”"
Versetzen 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Verwackelte Striche 26.6 - aus der Datei "“Filter Gallery.8bf”"
VueScan 1.0.00 - aus der Datei "“VueScan_x64.8ba”"
Weiches Licht 26.6 - aus der Datei "“Filter Gallery.8bf”"
Wellen 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
WIA-Unterstützung 26.6 - aus der Datei "“WIASupport.8li”"
Windeffekt 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Wireless Bitmap 26.6 - aus der Datei "“WBMP.8bi”"
Wölben 26.6 - aus der Datei "“Standard MultiPlugin.8bf”"
Optionale Zusatzmodule und Zusatzmodule von Drittanbietern:
Exposure X7 Autolayer 7.1.8 - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\Exposure Software\Exposure X7\Exposure Software Exposure X7 Autolayer x64.8li”"
Filter Forge 13 13.005.4275.16226 Release, February 15, 2024 12:59 - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\Filters\Filter Forge 13\Filter Forge 13 x64.8bf”"
Reduce Noise v9 9.2.3.0 - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\NeatImage9.8bf”"
Topaz Photo AI Beta NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAIBETA.8bf”"
Topaz Photo AI Beta NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAIBETAAutomate.8bi”"
Topaz Photo AI NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAIAutomate.8bi”"
TPAIApplyImageDataFilterBeta NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAIBETAApply.8bf”"
TPAIGatherImageDataFilterBeta NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAIBETAGather.8bf”"
Exposure X7 7.1.8 - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\Exposure Software\Exposure X7\Exposure Software Exposure X7 Photoshop x64.8bf”"
Exposure X7 Autolayer 7.1.5 - aus der Datei "“Exposure Software Exposure X7 Autolayer x64.8li”"
GigapixelApplyImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazGigapixelAIApply.8bf”"
GigapixelGatherImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazGigapixelAIGather.8bf”"
PortraitPro 5.0.0 - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\PortraitProPSFilter64.8bf”"
Reduce Noise v9 9.1.6.0 - aus der Datei "“NeatImage9.8bf”"
Topaz Gigapixel AI NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazGigapixelAIAutomate.8bi”"
Topaz Photo AI Beta NO VERSION - aus der Datei "“TopazPhotoAIBETA.8bf”"
Topaz Photo AI Beta NO VERSION - aus der Datei "“TopazPhotoAIBETAAutomate.8bi”"
Topaz Photo AI NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAI.8bf”"
Topaz Photo AI NO VERSION - aus der Datei "“TopazPhotoAIAutomate.8bi”"
TPAIApplyImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAIApply.8bf”"
TPAIApplyImageDataFilterBeta NO VERSION - aus der Datei "“TopazPhotoAIBETAApply.8bf”"
TPAIGatherImageDataFilter NO VERSION - aus der Datei "“C:\Program Files\Adobe\Adobe Photoshop (Beta)\Plug-ins\TopazPhotoAIGather.8bf”"
TPAIGatherImageDataFilterBeta NO VERSION - aus der Datei "“TopazPhotoAIBETAGather.8bf”"
Home Screen (Geladen) 8.3.0.35 - von der Datei "Erforderlicher Ordner"
CmdN: 1.23.5
UAB: 2.18.0-8
Geladen nach: 205 ms – Einfluss auf die Startzeit: 55 ms
CCX Commenting UXP Webview (Geladen) 30.7.0.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 5038 ms – Einfluss auf die Startzeit: 0 ms
CCX Sharesheet UXP (Vorbereitet) 30.24.0.0 - von der Datei "Erforderlicher Ordner"
Photoshop Facepile (Geladen) 1.8.0.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 219 ms – Einfluss auf die Startzeit: 0 ms
Monogram Creative Console (Vorbereitet) 1.1.1.0 - von der Datei "Plugin Marketplace"
Easy Panel (Vorbereitet) 1.0.0.0 - von der Datei "Plugin Marketplace"
TK Luminosity Mask (Vorbereitet) 1.4.0.0 - von der Datei "Plugin Marketplace"
Geladen nach: 4502 ms – Einfluss auf die Startzeit: 0 ms
CC Libraries Panel (Vorbereitet) 4.10.73.0 - von der Datei "C:\Program Files\Common Files\Adobe/CEP/Extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_73\"
Generative Workspace (Vorbereitet) 0.0.20.0 - von der Datei "Erforderlicher Ordner"
In app notifications (Geladen) 2.0.25.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 5039 ms – Einfluss auf die Startzeit: 0 ms
Photoshop Adjustments Panel (Geladen) 2.3.4.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 2969 ms – Einfluss auf die Startzeit: 1 ms
Photoshop UXP Export-As (Vorbereitet) 5.12.1.0 - von der Datei "Erforderlicher Ordner"
Photoshop In App Messaging (Geladen) 4.5.6.0 - von der Datei "Erforderlicher Ordner"
Share Panel (Vorbereitet) 1.0.12.0 - von der Datei "Erforderlicher Ordner"
Geladen nach: 4503 ms – Einfluss auf die Startzeit: 0 ms
Geladen nach: 4504 ms – Einfluss auf die Startzeit: 0 ms
Discover Panel (Geladen) 2502.118.0.9 - von der Datei "Erforderlicher Ordner"
Geladen nach: 5040 ms – Einfluss auf die Startzeit: 17 ms
Scanzeit: 4 ms – Einträge: 50
Erweiterungen:
Bibliotheken 1.0.0 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_73\index.html”
com.adobe.stock.panel.licensing-embedded 4.0.35 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_73\extensions\stock-panel-licensing\index.html”
com.adobe.capture.extension 2.0.41 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_73\extensions\capture\capture.html”
Monogram Extension 4.0.39 – aus der Datei “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\MonogramExtension\index.html”
com.adobe.cclibraries.manager 1.0.0 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_4_10_73\manager.html”
Logi Options+ v1.88.697541.0 7.0.0 – aus der Datei “C:\Program Files\Common Files\Adobe\CEP\extensions\LogiOptionsPlusAdobe\index.html”
Hope this helps.
CShubert
Apr 9, 2025 8:28 PM UTC
Hey everyone, sorry this has taken a while to get back to.... thank you for the sysinfo @pascalm3859019 .  @m3t4ll1k are we to assume you are the same, WIN customer?
First step will be to do a clean install of Ps beta.  I know you mentioned that you are seeing it on Ps release version, but we need to make sure.
Try resetting Prefs for the Beta:
/Users/yourname/Library/Preferences/ Photoshop Beta Settings (Mac Ventura)
/Users/yourname/Library/Preferences/Adobe\ Photoshop\ \(Beta\)\ Settings (Mac)
C:\Users\user name\AppData\Roaming\Adobe\Adobe Photoshop (Beta)\Adobe Photoshop (Beta) Settings
Launch BETA Photoshop While Pressing The Keyboard Shortcut
With Photoshop closed, press and hold Shift+Ctrl+Alt (Win) / Shift+Command+Option (Mac) on your keyboard and then Launch Photoshop the way you normally would.
https://helpx.adobe.com/photoshop/using/preferences.html#Manually 
@m3t4ll1k  It may help if we could see your Photoshop beta System Info. Launch Photoshop beta, and select Help >System Info...and copy/paste the text in a reply.
pascalm3859019
Mar 31, 2025 6:00 AM UTC
Hmm, doesn't seem to be of interest for Adobe...
