Open for Voting
Corner Pin and left upper corner glitch
While setting parameters for Corner pin, it makes the image move to the upper left corner when using UDH footage in a HD setting with scale set to 50%.
Solved when setting it to 50.1% but that is an annoying workaround for multiple clips.
It used to do this with Warp Stabilizer....
