collen
Feb 21, 2023 10:20 AM UTC
Open for Voting
Make Audio Channel Mapping settings stick after audio interface re-plug or power cycle
I use Audition CC (currently on 11.0.2.2) with an Audient ID14, and I work as a voiceover artist.
I nearly always record straight to the single track, not multitrack, waveform viewer. For my studio setup, I need my Audio Channel Mapping screen to be set to:
1 [L] (Mono) Analogue 2
2 [R] Analogue 1
Whenever I unplug and replug my audio interface, or power-cycle my computer, these settings reset to the default of:
1 [L] (Mono) Analogue 1
2 [R] Analogue 2
Audition should save that setting in it's Settings folder when you close down Audition. However it appears that it doesn't.
Confirmed this occurs on latest version of Audition (v12) as well in the forum:
https://forums.adobe.com/message/10689121#10689121
    Feb 21, 2023 10:40 AM UTC
    I am having the same problem. Is there a fix or work-around?
    anotherlab
    Feb 21, 2023 10:39 AM UTC
    I see this with Audition v13.0.5.36 on Windows 10. I lose the channel mappings if unplug and plug back in my headphones.
    sac86738
    I'm in VO too, and have the same problem, only my mappings are different for different reasons. Bug still present on v12.1.0.182, macOS Mojave.
    I'm having a similar problem. Running V 12.0.1.34 on Win 10. My channel mapping settings drop to "none" when the computer goes to sleep, even without shutting down Audition. How do I get Audition to save the settings?
