Mahty
Feb 4, 2017 9:27 PM UTC
I'm sorry, nobody can help me with my problem: no audio in Timeline
I'm sorry, but I gonna change Premiere pro by Final Cut Pro, because nobody can help me with my problem. I try all the possible solutions, but doesn't work. So I gonna change my video editing software.
Mod: Title is updated
Feb 8, 2017 9:24 PM UTC
Hi Mahty,
I see by the tags you added to your post that you had trouble with adding audio to your timeline. That is a common problem solved by making sure your track is patched. Did you do that? Please check this FAQ: FAQ: Why does audio or video not go to the track where I drop it?
Hi Mahty,
Feb 8, 2017 9:21 PM UTC
Hi Mahty,
Sorry to have let you down.
Please come back with specifics about your problem, and I'll do my best to solve it.
Thank You,
John T Smith
Feb 5, 2017 4:15 PM UTC
This is your one and only message here Mahty
If you really want help, post a message in the main forum Community: Premiere Pro |Adobe Community
When you do, you need to provide problem details so someone may try to help
-Troubleshooting https://forums.adobe.com/thread/2261475
-Premiere Pro Video Editing Information FAQ http://forums.adobe.com/message/4200840
-WITH Exactly which version of Premiere Pro
-WITH the brand/model graphics adapter (ATI or nVidia or ???) and exact driver version
-Do not count on Windows to be fully up to date when it comes to device drivers
-Go to the vendor site to be sure you have an updated driver for your graphic adapter
•nVidia Driver Downloads http://www.nvidia.com/Download/index.aspx?lang=en-us
•ATI Driver Autodetect http://support.amd.com/en-us/download/auto-detect-tool
-WITH have you recently updated to the very latest Mac or Windows operating systems?
--Both Windows 10 and Mac El Capitan have been known to cause problems... what is YOUR operating system?
-WITH exactly what are the codec details of what you are editing?
-WITH what effects are you using with the video?
-WITH exactly what export settings did you use for your output?
Feb 5, 2017 10:02 AM UTC
Did you ever Contact Customer Care - Premiere Pro chat and asked for a video queue?
shooternz
Feb 5, 2017 4:41 AM UTC
You never posted any issues here in the PPro Forum from what I can tell.
You give up quick!
