Mar 10, 2020 8:25 AM UTC
Need Help! I Need a Monitor For PhotoShop Work.
I need your help. I'm an amateur photographer and my hobby is editing photos so for now i'm just learning. So far i ve been editing on my laptop but for better color reproduction I bought a cheap photography monitor viewsonic vp2458 which is factory calibrated.
But, Now, I am looking for a professional monitor for photoshop work. Suggest me some Good Monitors for that. My Budget Is 500$.
Thanks
    Oct 10, 2020 1:27 PM UTC
    Checkout Dell S2417DG Monitor. it has Some really Good Specifications. But it cost little high. About 200$ monitor.
    Mar 10, 2020 6:05 PM UTC
    I suggest you to go with  ASUS PA248Q inches Monitor. it will cost you around  250 USD dollars. Since you have 500 US dollars budget, then you can also go with Dell UltraSharp U3415W 34-Inch Curved LED-Lit Monitor it has everything that you need to edit photos. Also, i found one article on internet where all monitors for photoshop are mentioned. You can refer to that. Cheers!
