Select and copy Text very often doesn't work with Adobe Acrobat Reader. What could be the problem?
  • January 18, 2023
  • 20947 views
I'm on Windows 10 and no matter what i try, no matter how i mark text (doubleclick or left mouse button down + drag + left mouse button up or even menu/edit/select all), most of the times (but sometimes it does work for the same document where it previously didn't, and while it's still open, no close/reopen has been done), copying text (with CTRL+C, with Right-Mouse-Button-Context-Menu + Copy, with the popup-toolbar and its copy icon or with menu/edit/copy) doesn't copy anything to the clipboard.
Copying the same marked text from the same document with the chrome pdf plugin always works.
I'm testing with the newest Adobe Acrobat Reader (V 2022.003.20310 64-bit).
Here's an example file where sometimes copying works and sometimes it doesn't:
https://www.adobe.com/support/products/enterprise/knowledgecenter/media/c4611_sample_explain.pdf
Note that i did click on "enable all features" when the warning about a potentially unsafe document has been shown.
The "Document Properties" show under Tab "Security", Line "Content Copying": Allowed.
This is awfully annoying and some friends told me they have the same problem so that i don't think it's just my pc.
Correct answer Ridil28000261xpvn
Unfortunately not. I'm still having the problem on multiple systems.
It's also worth pointing out that it's not like Acrobats copying isn't doing anything; when there's already something in the clipboard and i'm copying from acrobat, the clipboard get's cleared, so acrobat is actually doing something, just not enough or the right thing.
JR Boulay
[MOVED TO THE ACROBAT READER DISCUSSIONS]
Amal.
Hi @Ridil28000261xpvn
++ Adding to the discussion
Would you mind sharing a small video recording of the steps you are doing and the issue you are experiencing?
Also, please collect  the Adobe CC logs https://helpx.adobe.com/creative-cloud/kb/cc-log-collector.html  , Procmon logs (Win Only) https://www.adobe.com/devnet-docs/acrobatetk/tools/Labs/acromonitor.html  and share them via document cloud as described here https://helpx.adobe.com/document-cloud/help/sharing-pdfs.html  for further investigation.
Regards
Amal
Hi Amal
This is a company pc and i'm not allowed to install those data collectors. Do they show the complete data they're gathering and allow to manually delete some before uploading? Is the upload automatic or is it possible to cancel?
However, i did a screen recording of the behavior; please find it attached.
Ok. How is this the correct answer? I feel like it only adds more evidence to the suspicion that there's a very annoying bug in acrobat reader.
Dave__M
For what it's worth, I am running Windows 10 & Acrobat Pro DC Pro - and copying text functions as expected on your sample document.  A thought, though, is that the file opened for me (after clicking the link) in a browser, and my browser settings instruct an online PDF to be displayed in Adobe's browser plugin.  When opened in the desktop Acrobat application, it also behaved 'properly'.  Are you trying to copy the text from inside a browser presentation of the PDF?
Any additional details you can provide might help isolate the issue.  (And I understand that I am not using Reader, but Acrobat - trying to reproduce your issue with the tools at hand.
My best,
Dave
Hi Dave
I downloaded the file to a local harddrive and opened it from there with the newest Adobe Acrobat Reader (V 2022.003.20310 64-bit).
Then i also opened the same downloaded file in the newest chrome for comparison.
