whistlera27944350
해결됨
http://helpx.adobe.com/creative-suite/kb/acrobat-failed-launch-30-days.html is not working and need acrofix.exe as Acrobat X Pro is not working after installation along with CS6
  • July 3, 2016
  • 1 답변
  • 1328 조회
Please provide non 404 link to Acrofix.exe as http://helpx.adobe.com/creative-suite/kb/acrobat-failed-launch-30-days.html  is not working.  I've Acrobat X Pro that was installed with CS6 and it is not working.
이 주제는 답변이 닫혔습니다.
최고의 답변: try67
The Spanish version of this page still works. You can get the Acrofix.zip file from there: No se inicia 30 días después | Instalación como parte de un paquete CS6
1 답변
try67
try67Community Expert답변
