PDF Embed: GUID format, is not a standard GUID
We're using the Adobe generated annotation ID guid for records we're saving into our database.
Here is an example:
"5b88956c-f62b-8c17-32h8-286beb8e8b5"
Which type of GUID format is this? It does not adhere to the UUID standard.
https://www.uuidtools.com/decode
It appears this format is not adhering to the UUID standard. Can someone confirm which UUID standard the annotationId is?
