Jun 11, 2022 8:36 PM UTC
dpm.demdex.net web blockage and excessive use of battery power
1. How can I stop dpm.demdex.net from blocking access to my favourite streaming channel (Channel 4.com)?
2. Can I reduce the amount of battery power consumed by dpm.demdex.net? It is currently my highest battery user on my macbook, as weel as acting as a web blocker,
Meenakshi_Negi
Jun 13, 2022 7:33 AM UTC
Hi Malcolm,
Thank you for reaching out.
Could you please elaborate on the issue you are experiencing?
Do you get any error messages? If yes, would you mind sharing the screenshot?
Are you using any Adobe services?
Meenakshi
Jun 13, 2022 11:04 AM UTC
Thanks for responding Meenakshi. Here is a screenshot. This is happening with both Safari and Firefox/DuckDuckGo. I use Adobe Reader DC. My DuckDuckGo 'privacy essentials' shows dpm.demdex.net asthe only adblocker.
Meenakshi_Negi
Jun 19, 2022 1:41 PM UTC
Thank you for sharing the screenshot.
Would you mind sharing the screenshot of the settings where it says dpm.demdex.net as the ad blocker?
It does not seem to be Adobe related, as each browser has there own ad blocker, which you need to disable from the browser settings.
Please let us know the steps you do to disable the ad blocker from the browser.
Meenakshi
