Oct 11, 2018 2:26 PM UTC
Graphpad Prism fonts in Power Point will not show in PDF
GraphPad Prism graph fonts are correct  in PowerPoint, but are markedly reduced in size in the PDF.
Saving/pasting graphs as various photo formats did not resolve the problem.   Help.
    AkanchhaS8194121
    AkanchhaS8194121Correct answer
    Oct 19, 2018 9:14 PM UTC
    Hi Frederich,
    Sorry for the delay in response.
    We see that you are using the Adobe PDF Pack, and I believe you are trying to create a pdf through ppt?
    PDF Pack is an online service, which can be used via web browser or
    You may try the conversion using web browser  Adobe Document Cloud  and see if that makes a difference. You may also check with a different file and see if that makes a difference.
    Akanchha
    AkanchhaS8194121
    Hi Frederich,
    Akanchha
