@edinburghorchardnursery Thanks for posting, and sorry you’re having the same issue! I got some more guidance from the team on how we might be able to find it on our own - since some Stock assets get removed (e.g. contributor blocked or asset deleted), and when that happens Express can no longer license them.
1. Try “Source info” (if available)
• Right‑click an image/design asset and choose Source info.
• If it shows an Asset ID, that’s likely a Stock asset. If you see an asset that no longer opens on stock.adobe.com, it’s probably been removed and must be replaced.
2. Trial‑and‑error replacement
• Focus on any Stock‑looking photos/backgrounds/icons in the page.
• Replace or delete them one at a time, republishing after each change.
• When the licensing error disappears, the last item removed/replaced was the culprit.
You mentioned you’ve already tried workaround #2, so mind trying the steps in #1? If it’s a large project with too many assets, then go ahead and DM me the URL with edit access, and I’ll have the team take a look. (Make sure to make a copy just in case).
Rose
