Jul 12, 2021 5:03 PM UTC
Iridescent Material Problem - Unreal Engine 4.27
Hi, I've downloaded the "Iridescent Velvet" material from Substance Source.
How can I enable the iridescence in Unreal as the fabric after import looks flat and
doesn't have any iridescence out of the box.
I have tried importing as MDL - but it is awful to work with.
Hope you can help, thanks
Jakub
Jeremie Noguer
Jeremie NoguerCorrect answer
Jul 14, 2021 4:35 PM UTC
In this case, the irridescence is only available when downloading the MDL format.
Jeremie Noguer
Jeremie NoguerCommunity ManagerCorrect answer
