How to set parent project folder for safe transferring project between home and work PCs?
Hey guys, is it possible to set some some global path in SD similar to the way Houdini has it, for example $HIP/MyProjectSources/ where $HIP would be main root of the project directory containing all the subfolders with various textures I use in SD? I need it because very often I have to copy my substance project from work PC to my home PC and vice versa and while at home I may have MyProjectSources at C:/Projects/MyProjectSources, on my work PC it might be on Z:/FolderA/FolderB/FolderC/MyProjectSources and it would be nightmare to relink all the pathes manually. Is there some way to do that? Thanks!
