Mar 5, 2023 4:07 AM UTC
Audio quality problems in Audition when my microphone is selected as the input
I have a usb microphone that I use to record in Adobe Audition. I've used it before on my old computer the same way and never had a problem with it. I recently got a new computer (same model, just slightly upgraded specs) and when I went to record in Audition, I noticed the audio sounded signifigantly worse than it had on my old pc. I assumed it was a problem with my microphone. Went through a bunch of settings and nothing helped. Then I discovered that if I took an audio file from my file explorer (which sounds fine outside of Audition) and played it in the software, it also sounded horrible. The only thing I've found that can fix this is if I go into the audio hardware settings and set the default input to "no input" instead of my microphone. But that only fixes imported files that already sounded ok. It doesn't fix new files that I record in Audacity. And obviously I can't record without my microphone selected as the input device. So I'm not sure what to do. Any help would be very appreciated!
SteveG_AudioMasters_
Mar 5, 2023 11:51 AM UTC
If this is happening with previously recorded files, the almost certainly it's a playback issue. What is slightly strange is that altering an input option would alter this at all - can't see any good reason for that. Oh, and I'm presuming that you didn't mean Audacity, but if the same thing is happening if you record using it, then it rather confirms that it's a playback issue.
The first thing you need to do though is to confirm that this is happening in Windows, not on a Mac. Yes I realise that if you did mean Audacity, it almost certainly is!
Mar 5, 2023 9:54 PM UTC
Whoops, meant Audition, not Audacity. I don't use Audacity anymore. But I agree this seems like a playback issue, I'm just not sure what's causing it.
I'm using Windows 11.
Mar 6, 2023 12:49 AM UTC
Can you provide a screen-grab of your hardware settings, and also the sound settings you're using in Windows?
But I have to say that in the light of a few other weird things being reported here about it, this may be related to W11 - which I will not yet put on any machine at all.
