kili
Nov 14, 2017 12:58 PM UTC
Audition CC 2018 on W10 with REALTEK HD. Recording problem. Mike OK on speakers but is ignored by Audition CC. Solution?
    ryclark
    ryclarkCorrect answer
    Nov 14, 2017 9:15 PM UTC
    No I'm afraid not. Audition only records the audio that audio interface sends to it. What sort of levels are you seeing on Audition's meters? Normal recording levels would be between -18 and -9 dBFS on the meters. What mic are you using?
    ryclark
    Nov 14, 2017 4:43 PM UTC
    Do you see the Realtek as a Device in Audition's Preferences/Audio Hardware and have it selected?
    kili
    kiliAuthor
    Nov 14, 2017 6:45 PM UTC
    Thank you. Realtek is selected. I found just now that the mike signal enters the Audition CC but at a very very low level. Mike and speakers work fine but mike an audition not. Realtek recording is set at 100% level. Is it any way to adjust Audidition to work with very low level mike signals?
    De: ryclark
    Enviado el: martes, 14 de noviembre de 2017 13:44
    Para: Héctor Kilijanski <hectork@uolsinectis.com.ar>
    Asunto: Audition CC 2018 on W10 with REALTEK HD. Recording problem. Mike OK on speakers but is ignored by Audition CC. Solution?
    created by ryclark <https://forums.adobe.com/people/ryclark> in Audition CS5.5, CS6 & CC - View the full discussion <https://forums.adobe.com/message/9969683#9969683>
    ryclark
