JohnVo
Nov 3, 2016 8:18 AM UTC
audition cc multi track vst problem and question
hi
i haven't the time to update to audition cc 2017 , so i'm still running the last version of 2015
i have installed the trial version of acon equlize and fabfilter  pro q2 (i guess the best equalizator according about what i have read)
i 'm under multi track
i added both on rack effects
but when i try to control the effect i can't find anything
look the first screenshot , ok it's just a test , i know i have 2 equalizators on the rack just to make a test
in the second screenshot , i try to control the equalizator with keyframe but i get this menu
is the only way to control output level , right?
can somebody tell me what's the meaning of in the second screenshot for band 6 Q ?? i haven't in the fav pro q2 preset
JohnVo
JohnVoAuthor
Nov 3, 2016 5:17 PM UTC
hi
i have tried with cc 2017 ,cc 2015 and cc 2014 ,and i can't control for example rack 1 with a plugin vst or vst3
i can control only audition built in effects
is there a way to do it?
i can't find even how decrese or increase the effect
thanks
ryclark
Nov 3, 2016 5:33 PM UTC
You can only control the Envelopes that appear in the long list that appears when you click on FabFilter that you show in your second image. Audition will only show those adjustments that the plugin makes available to it. You can, of course, still perhaps use the Rack Input/Output/Mix and Power envelopes to control the level of effects within the Rack.
JohnVo
JohnVoAuthor
Nov 3, 2016 7:28 PM UTC
hi
Acon equalizer doesn't have any way to control the plugin,even it's a great plugin
Ryclark , may i know which plugins have you installed ?
and if you can controll them ?
thanks
