dancingbrook
May 22, 2017 6:01 PM UTC
Auto Heal & Noise Reduction w/ Noise Print
Anyone know of a plug-in for Audion or Logic that has the same ability for Auto Heal and Noise Reduction w/ Noise Print?
Seems Noise Reduction w/ Noise Print is still broken: "A severe error code was encountered (00000008)." No explanations or links to advice is simply bad coding.
    dancingbrook
    May 22, 2017 6:09 PM UTC
    Ahhh, spoke too soon; seems they have:
    An update for Adobe Audition CC 2017 was released this week resolving problems with the Noise Reduction effect, in addition to other bug fixes.  Please update Audition or visit May Update for Audition CC 2017.1 | Creative Cloud blog by Adobe for more details.
    Regardless, still interested in Plug-Ins as mentioned.
    May 22, 2017 6:54 PM UTC
    A number of users here, myself included, find the iZotope RX range, especially the "Advanced" versions, extremely useful in the area of Noise Reduction, but be prepared to shell out lots of bucks!
    Bob Howes
    May 23, 2017 5:00 AM UTC
    As you've discovered, the new version of Audition released last week fixes the noise print/Noise Reduction process.
    Yes, the high end Izotope product is excellent for remedial work on your audio--but for 99% of things, the built in Audition processes are more than adequate.
