Jul 17, 2023 5:39 PM UTC
Batch loudness correction sometimes adds small parts of audio from other tracks!
I think this may be a bug. I edit audiobooks and send sets of files (chapters) to Match Loudness to make them compliant with Audible specifications. I'm exporting WAVE files from Pro Tools, importing into Audition to the Match Loudness window, running Audition to the target loudness specifications I've set and then 'saving all'. It can be arund 8 to 30 files at a time.
Every so often there is a small piece of audio added to a file towards the end of it. It's not actually added onto the file it is pasted over the particular file that is corrupted. Usually about 2-5 seconds from the end and only around 2 seconds in length . Luckily these are usually easy to find but it's annoying to have to check every file.
I was wondering if anyone else had this problem or if it's a bug?
Running a Mac Studio on Ventura 13.3.1a,
Audition ver: 23.5.0.28
SteveG_AudioMasters_
Jul 18, 2023 2:45 PM UTC
I don't think you need two temp folders - certainly not if you don't have 22.0 on the system any more. In the temp folder settings there's an option to set up a secondary temp location too. I've never had it set, and nothing's ever gone wrong. The ideal situation is a separate drive just dedicated to temp folders - which is what I have on my DAW. If you can't run to a separate drive, then a dedicated folder on the root drive of your system is the next best thing.
InterfaceAuthor
Jul 17, 2023 10:48 PM UTC
Thanks for your response Steve.
My temp files are stored on my main hard drive. It's a reasonably new mac with ample storage space.
I did notice when I looked in the temp storage folder under Library/Caches/Adobe/Audition that there are two temp folders there one for the curent version I'm running (23.0) and one for the previous version (22.0), altough it doesn't look like the 22.0 folder is being accessed when processing.
Do you think having two folders in the same location for temp files might be the problem? If not where would you suggest to be the best place to save the temp files to?
Thanks
Douglas
Jul 17, 2023 8:45 PM UTC
I think that the trouble here may be that you are rather forced to do this in Waveform view, and this involves the use of a temp file (or indeed several of them). In general, things behave way better with temp files if you can set your primary temp drive to be in a place where it can't be 'disturbed' by other things going on. I know that this is a particular issue with Windows machines, and I'm not quite sure about the arrangements on Macs, but in principle the same thing could apply. But it really does sound like a classic temp file issue, though - that's the first place to look for trouble.
