Help needed to output 8 track audio master with six channel 5.1 surround and 2 channel
I'm trying to deliver a master output to a digtial aggragrator. I need to export a 8 channel audio master. Per the QC dept. it should be 8 total tracks. A1 to A6 should be 5.1 and A7 and A8 should be stereo.
I have output test clips, but the QCdept says they are only seen 6 tracks of audio. I was just reading I might need to create a new sequence with 8 tracks of audio. Six tracks being mono and Two tracks being stereo.
Does this make senese to anyone? Any suggestions on how to setup this master output sequence? Testing all sorts of things at the moment. Thank you all in advance.
