collen
Oct 18, 2018 2:19 PM UTC
How to make Audio Channel Mapping settings stick after interface re-plug or power cycle
Hi
I use Audition CC (currently on 11.0.2.2) with an Audient ID14, and I work as a voiceover artist.
I nearly always record straight to the single track, not multitrack, waveform viewer.  For my studio setup, I need my Audio Channel Mapping screen to be set to:
1 (Mono) Analogue 2
2 Analogue 1
Whenever I unplug and replug my audio interface, or power-cycle my computer, these settings reset to the default of:
1 (Mono) Analogue 1
2 Analogue 2
Is there any way I can save these settings so each time I reconnect my Audient, it resumes the previous settings?
Many thanks
    ryclark
    ryclarkCorrect answer
    Oct 18, 2018 3:39 PM UTC
    Audition should save that setting in it's Settings folder when you close down Audition. However it appears that it doesn't. I would log it as a bug with Adobe.
    However you are running a fairly old version of Audition. There have been several v.11.1 versions since yours and we are now up to v.12. So perhaps you ought to update your installation. But I don't think that this will get rid of your problem because I just tried in v.12 and it still came back with the default channel mapping order I.m afraid.
    ryclark
    collen
    collenAuthor
    Oct 19, 2018 10:37 AM UTC
    Thanks for taking the time to replicate for me ryclark.  I've logged as a bug here:
    Make Audio Channel Mapping settings stick after audio interface re-plug or power cycle – Adobe video & audio apps
    Also downloading v12 of Audition now.  Thanks
