Aug 29, 2025 9:27 PM UTC
How to remove slurping sound from audio recording? [I am begging for help!]
There is a weird noise happening in the beginning of this audio where it almost sounds like someone slurping. I cant identify it in wave format and ive tried every filter or noise gate or denoise i can think of but i cant figure out how to get rid of this. Can anyone help or am I cursed to have to rerecord?
Rag and Bone
Aug 30, 2025 9:19 AM UTC
I don't hear it. Can you tell me what word it occurs on?
MikeyA13Author
Aug 30, 2025 8:06 PM UTC
its between youre and the
MikeyA13Author
Aug 29, 2025 9:29 PM UTC
The Wave view if needed
SteveG_AudioMasters_
Aug 30, 2025 10:49 AM UTC
This is probably an artifact of the voice, and perhaps you should re-record it anyway... use a pop filter and don't have the speaker too close to the mic, or directly facing it - so speak across it. And no milky fluids first - just water.
MikeyA13Author
Aug 30, 2025 8:05 PM UTC
Unfortunately I do use a popfilter and speak away from the mic :'(
