I used Capture Noise Print to remove water faucet sound...
I was listening to a file and it's good. Then somebody turned on a water faucet and I heard the water running. In the spectral graph I saw the water flow start -- there it is, a band of sound going through the narration. I wondered, Is there a way to remove that band without removing the voice that it's going through?
Since this was a constant sound I think I pretty much figured out how to remove it without hurting the rest of the sound. I used the Capture Noise Print and NR process. I think it worked!
