MP3 Conversion Issue: Inconsistent dBFS Reduction for Long Audio Files in Audition
Hi Adobe,
I used Audition to generate a 1-hour 0dBFS 1kHz tone and saved it as a .wav file without any issues.
However, after converting the file to .mp3, closing it, and re-importing it into Audition, I noticed that the dBFS of the .mp3 file was reduced. The amount of reduction varied inconsistently.
If the audio file is 1 minute or shorter, this issue does not occur.
I tested this with both the 2024 and 2025 versions of Audition, and the issue persists in both.
Best regards,
Jeffery.
