angelat92401595
Jan 25, 2018 1:44 PM UTC
Multi track recording MUCH FASTER than actual conversation speed - please help
I used the multitrack option to record a show (Pressed R for record on the track and the red button at the bottom- when I went to edit the recording it was about 150 percent speed of the actual conversation... and had crackling and hisses....
Does anyone know what caused this and if it can be fixed?  I am a beginner, but have recorded about 100 times and have never run into this problem,f
    SuiteSpot
    Jan 25, 2018 3:58 PM UTC
    I would say that your session sample rate doesn't match the sample rate that you recorded at
    eg session is 48k and the audio file is 44.1k
    The crackling could be that your buffer size is way too low - try increasing it
    Edit > Preferences > Audio Hardware
    ryclark
    Jan 25, 2018 4:04 PM UTC
    But unmatched 44.1/48 sample rates wouldn't speed up that amount, 110% at the most. But certainly mismatched sample rate between audio hardware and Audition's session might cause the problem. What Operating System are you using and what audio interface are you using with Audition?
    angelat29271274
    Jan 25, 2018 5:51 PM UTC
    Thank you so very much for responding!
    The microphone was a USB AUDIO CODEC for input
    speakers USB AUDIO CODEC
    The latency was 30 and i just upped to 200, and it did help the crackling in one of the audio segments.. i haven't tried the other.
    The weird thing is that in the first part of the first file..its going VERY FAST, then it seems to settle down for about a minute.. then fast again..
    The sample rate was 44100-
    How do i match up the sample rates?
    The bottom of the screen is 44100 .. but I don't know how to check the the rate I recorded at versus the sample session?
    The PC is Windows 10 home
