Danko_Cimbri_Photography
Jan 9, 2018 6:32 PM UTC
Problem with Adobe Audtion CC Build 11.0.0.199 - Delay between recording microphone and audio output in the headphones - Impossible to sing - Unlistenable eco effect!
Hello everybody,
I have Adobe Audition CC (version Build 11.0.0.199) and I would like to use it for singing records and listening them in live in my headphones.
I've already connected the microphone to my Mac, as well as the headphones and then I've set the Hardware Audio entry on the microphone and the output on the headphones. Until now, everything's good.
The problem is the following:
when I press on "write" and then "record", the moment from which I sing and the moment when I actually hear my voice in the headphones is about 1 second delayed. How can I eliminate this annoying delay? It's like I sing in the middle of a canyon.
Waiting for a response, here are some data on the devices in use.
Microphone:
  • Trust All Round USB
  • Microphone Mico
Headphones:
  • Beats Solo
  • Model: B0518
iMac Information:
  • iMac Retina 5K, 27-inch, Late 2015;
  • Processor: 3.2 GHz Intel Core i5;
  • Memory: 8GB 1867 MHz DDR3;
  • Graphic Card: AMD Radeon R9 M380 2GB
Thank You all!
SteveG_AudioMasters_
SteveG_AudioMasters_Community ExpertCorrect answer
Jan 9, 2018 7:19 PM UTC
