May 8, 2017 10:21 AM UTC
Problem with Sound Max Analog Devices and AA3 when recording Internet audio
I'm having a problem recording Internet audio with Audition 3 on Windows 7 using Sound Max.
This problem began last week. Before that this combination has been working great for many years without any problems at all.
When I'm recording Internet stream I open "Stereo Mix" channel. I used to adjust the channel 2/3 open and in this point the recording level was fine and the recording used to go smoothly and the result was fine. But now when I open the ""Stereo Mix" only a tiny bit the right channel go "red level" and other channel goes almost the same level. When I play back the recording there is no audio at all but only some static noise.
I can't understand what has happened? Do I need to install AA3 or SoundMax again?
Any help would be very much appreciated.
Tony
    ryclark
    May 8, 2017 11:33 AM UTC
    Do previously recorded files play back OK from within Audition and/or other media playing software?
    May 8, 2017 11:56 AM UTC
    Yes they do. No problem playing them back.
    May 15, 2017 10:02 AM UTC
    I succeeded in removing and reinstalling the AA3 to my PC.
    However when I try to monitor record level when recording I get the following message and the recording file will be empty without any signal:
    Again I can play back my previously recorded files and AA3 shows playing back levels as well.
    So what next?
