johnt53984649
"Rulers" for Multi-track Sessions
  • March 14, 2017
  • 4111 views
Is there any way to add "rulers" to multi-track sessions in Audition?  What I mean by this is creating a line across the timeline that behaves similarly to a ruler in Adobe Photoshop; any audio clip could easily be snapped to that ruler by simply dragging the clip up to it.  The main advantage of this would be that multiple rulers could be created in consistent intervals (possibly through a dialog box or something) so that audio clips could be repeated more easily.  Is there any way to do anything like this in Audition?
    Correct answer SteveG_AudioMasters_
    Audition's multi-track view has an infinite number of rulers - every time you move a clip you get a blue vertical line on the screen as it passes significant events (you can select these). So lining up a load of clips is easy; you set the snapping to 'snap to clips (right-click on the timeline to get this option easily), and position the first clip where you want it. When you put another clip on an different track and drag it, you'll get the blue line showing and the clips will 'snap' together - and this is sample-accurate.
    I have a question regarding the ruler in multi track. At the beginning of the ruler it says (hms),  I'm trying to figure out what that stands for.  Is it hours meters seconds?
    Hours:Minutes:Seconds, so you were nearly right!
    SteveG_AudioMasters_Community ExpertCorrect answer
    Videotrack
    Hi, Can you help me solve an issue with adobe audition CS6 please?
    In order  to align two audio tracks at the same audio point in a multitrack session I created a cue marker on each track.
    Then I choosed Edit, snapping, and snap to markers and clicked the Toggle Snapping icon  at the top of the Editor panel.
    When I move the first track to match its marker with the marker of the second track the snap is not working...
    In other words, the markers are not snapping with each other...
    I can’t understand the reason why it does not work.
    Can You help me please ?
    Tank you so much.
    Luigi
    Ahi, ahi! I thought it would be possible to insert a marker into the audio point of each single
    clip as sync point, and then simply align the markers exactly as it happens in Premiere pro...
    Markers on a file aren't the same as markers on multi-track's timeline. File marker points (which do show up as dotted lines, if you look carefully) shift when you move the clip you've taken from it. Multitrack markers only show up on the multi-track timeline and aren't related to clips at all.
    But as far as I know, you can still snap to these dotted markers whilst moving the clip around, so you shouldn't have any real difficulty if you want to do it this way.
