Resuelto
Specific mono conversion (CCITT u-Law 8.000 kHz, 8 Bit, Mono)
  • February 21, 2017
  • 2 respuestas
  • 19801 visualizaciones
I recorded some "On-Hold" messages for our phone system which I produced the finals in Audition CC.  Unfortunately it ends up that the phone system (Avaya) requires a specific recording type and I'm not figuring out an export scheme to match what it requires.
Will someone knowledgeable on audio formats and the ability of Audition to export to this format let me know the settings or if it's even possible?
Dave
Mejor respuesta de SteveG_AudioMasters_
In that case, probably these settings:
2 respuestas
SuhrabS17
use this link to convert your audio to CCITT u-Law 8.000 kHz, 8 Bit, Mono
https://g711.org/
jasonh21189773
Ok, while this is again resurrecting a long dead thread, I was doing some digging and I believe Spencer got it right above, and I have an explanation of why. If you set the Sample Type in Audition to 8k, 8-bit Audition will (in its order of encoding) first do the sample rate conversion to 8K, 8-bit Linear PCM and THEN convert to uLaw 8-bit PCM (which is logarithmic, not linear). If you leave the bit rate in the Sample Type section alone (whatever you started with) then the initial conversion just changes the sample rate but not the bit rate, then will convert the higher bitrate audio to the correct uLaw 8-bit PCM format and because the full linear data was there to at the beginning of that part of the process (rather than being discarded with an 8-bit sample rate conversion) the logarithmic conversion has doesn't introduce all of the noise. Quality will always be low because it is 8k (and we all expect that) but the noise is avoided.
Does that sound correct according to the physics?
You haven't said what the extension is, but the principle's the same whatever you use. Most probably the correct format container will be in libsndfile, so what you are looking for is something like this:
So you use the pulldown  at the end of the line to select the format, and then click on 'change' to select the type of recording you want (8k 8-bit mono), and in the 'format settings' box use Change to select something appropriate (which is slightly wrong in that picture!), and then put the extension you want on the end of the file name.
If you haven't done this before, then there are a few things you need to be aware of before saving in such a restricted format. I covered most of it in another thread not so long ago, and you can see that here:
Audio Format File Conversion
Taschia R
I know this thread is over 7 years old at this point so this is a long shot, but @SteveG_AudioMasters_ I've seen your responses in a few different places and your insight and assistance here has been immensely helpful! Unfortunately, it looks like the old hyperlinks to the more in-depth threads you mention are broken (Like this one to the Audio Format File Conversion), possibly because it looks like Adobe overhauled the forum URLs at some point -- and I've been looking for an hour but finding the post in the depths of the forum backlog is proving difficult. I'm extremely interested in reading your guides though! I was wondering if that information is in fact still floating around somewhere, or if you'd be willing to revisit the topic? I don't want to ask too much or make you write entirely new threads though, maybe compiling some new working links to some of the more in-depth write ups you've done over the years in one place? I'm not sure the best solution, I just know the current navigation and search options for the forums are being extremely unwieldy haha.
But hey, if you actively post about audio engineering in other spaces or about other software as well, I'd love to know!
Regardless, thank you so much for all your time and effort in these forums - You've clearly been around a while and know what you're doing, and are passionate about helping make the information accessible for people, thank you so much!
Sorry, don't have time to redo any of this, but also, I'm not sure what has happened to the old threads. Yes, Adobe 'rebuilt' the site a few years ago, and this effectively rendered every single previous link useless. There doesn't appear to be any cross-linking of thread numbers and they also ditched the rather useful FAQ section that we used to have. I'm not really sure what the purpose of the rebuild actually was, but it does not appear to serve the end users very well...
So it's possible that it's still there, but a search doesn't reveal it to me either, I'm afraid.
