vsevolodp86344039
Sep 30, 2017 7:45 AM UTC
Stereo sound fx on mono audio track in 5.1 project
Hello! I have a 5.1 project. I use some stereo sound effects on the mono track to make it sound from the center channel. The analyzer shows that now it is mono. But what about downmix 5.1 to stereo? In this case, will the stereo fx on the mono track remain mono or as a source in stereo? Thank you!
ryclark
ryclarkCorrect answer
Sep 30, 2017 9:20 AM UTC
Try it and see. It will be much easier if you have the session set up for you to test what happens by doing a trial mixdown to see if it comes out how you want it to sound.
ryclark
