Dec 5, 2019 5:40 AM UTC
When removing noise using Adaptive Noise Reduction, it leaves some noise at the beginning
When removing noise from sound file using Adaptive Noise Reduction, it leaves some noise at the beginning! I'm using version 13. I was hoping to get tthis resolved very quickly but Adobe does NOT provide phone support! Also, when increasing the volume of short bursts of sound, it no longer sounds like the original, which is very poor. How can these issues be resolved soon?
WCarpAuthor
Dec 6, 2019 1:24 AM UTC
SteveG_AudioMasters_
Dec 5, 2019 10:17 AM UTC
Further to what Mike said, you have to realise that in ANR's name, the 'Adaptive' part is significant. It has to read a part of a file before it can react to what it analyses as noise, and this takes a finite amount of time. Also, this applies to changes of noise within the file, so if the nature of the noise changes abruptly at any point, the same thing is likely to happen - it won't catch the start of it.
Adaptive Noise Reduction works best on sources where there are gradual changes of noise; in principle it can handle this better than the 'normal' NR, but it's not as good for constant sources. And all NR is at best, a compromise - if you have a very poor signal to start with, then any NR you do to it is going to make that more obvious, I'm afraid.
Mike Russell
Dec 5, 2019 6:39 AM UTC
Adaptive Noise Reduction takes a second or so to kick in. You can't change this so better to use DeNoise or Noise Reduction if you want something that works immediately from the start of your audio.
