jsvfoto9485530
Audio issues with trimming...
  • June 29, 2015
  • 3982 views
I trimmed a video in captivate. When I play the video at the place where I trimmed it, the audio track continues like it was never trimmed, and a new audio track starts from the ending place where I trimmed the video. In other words the video portion got trimmed, but not the audio. Basically it's like having two audio tracks playing. I hear both tracks in Captivate and when I publish the project. I then tried trimming the audio first by editing it, and then by trimming the video, but I get the same result. The video gets trimmed correctly, but the audio portion ends up with two tracks (one is the original and the other is the trimmed version). Any ideas what may be causing this?
LinPea
I figured out how to remove the double audio after messing around.
On the right hand side of the editing window you'll see all your trimmed audio clips from trimming the video saved here...
Double click the audio clips near the bottom (last trimmed) and click "edit" to listen to the clip. Once found just close the window and right click on the audio clip to delete. It worked for me and now I don't have 2 audio clips over lapping.
I was experiencing this same issue and this resolution worked for me!  Thank you so much!  I've spent more time than I care to recall trying to deal with the problem of "double audio" when trimming. No idea why it's happening in the first place, but glad you found a solution. Thanks Again!
samanthal42331953
I have also been experiencing this issue.  I have reported it to adobe support, and was told that this issue "has never been reported", despite this post and my previously reporting the issue myself.  I was told that updating Captivate typically fixes bugs like this, but it did not fix it for me.  I am using the latest version of Captivate 2017.  If anyone has experienced this and found a fix, or stopped using captivate due to a lack of a fix, I would greatly appreciate hearing about your experience.  Thank you!
I experienced the same issue with my project. I add all the audio to my objects, as I have to translate the training into six different language. When I preview the training, it seems to work fine but once I check it inside the browser, I noticed that the audio cutts off at the end of the audio file. I used Audition to add silence at the start and beginning of my audio file but every time I use the files inside Captivate, it gets trimmed automatically and causes the same problem again and again. It caused many hours of work already and I'm really done with Captivate.
Lilybiri
Do not add 'silence' but 'background noise' in Audition.
jsvfoto9485530
An update: for whatever reason, even after clearing the CPVC cache, it looked like the audio was trimmed (and I checked by going in to edit the audio and it "appeared" to be trimmed), but the audio wasn't really trimmed. The video was definitely trimmed, but not the original audio. It kept playing. The latter audio (from the trimmed video) also played on the video so that in essence two audio tracks played after my trim point, even in the published version.
Not sure if this will help someone, but what I ended up doing was I edited the audio first and then edited the video. It worked! It was a pain, because I had to keep track of multiple timelines, since the main timeline wasn't actually edited, just the audio. Still, it's a work around and I hope this little tip helps someone save time. I spent the better part of a day trying to figure this one out.
Very strange -- I'm having a similar problem now. Did you figure out if there's a workaround from the get-go? In other words, a way to ensure that both video and audio are being edited simultaneously, or is this just a weird glitch?
josev6861445
I saw your post and wondered if you were referring to my issue. Unfortunately, I was never able to fully resolve this with my original hardware setup.
A few questions for you...are you using a Lenovo Txx laptop? Second question, how much RAM do you have in your machine? Third question, what kind of disc do you use spinning or SSD? I don't know if changing to an SSD or upping my RAM to 16GB made the difference, but one of these upgrades solved this odd dilemma for me. I had both upgrades done at once, and once they were in place this issue went away.
If push comes to shove, just publish your video as an MP4 and edit it using Windows Movie Maker or Corel Video Studio or Premiere Pro. I've been using Premiere Pro for the past few months to edit videos and what a difference that program makes, especially round-tripping the audio with Audition!
