Cant't create project using existing Power Point presentation..help
  • October 5, 2015
  • 5 replies
  • 339 views
I got Captivate 9.0 installed on my computer and I am a new user. I have taken the tutorials and training everything seems to work with the exception of the Power Point functionality....any thoughts, suggestions?
    mohanadas
    Adobe Employee
    Adobe Employee
    October 6, 2015
    Can you explain what exactly is not working for you regarding the Powerpoint functionality? Are you able to import existing PowerPoint presentations or PPTX?
    For more information please refer: Adobe Captivate Help | Microsoft PowerPoint
    Mohana
    brendajpAuthor
    Not at all.  I tried different presentations and nothing happens.  I go to my task manager and it shows that Captivate is running but nothing happens nor can I select anything on the screen..  If quite frustrating....
    mohanadas
    Adobe Employee
    Adobe Employee
    October 7, 2015
    Can you tell me which OS you are using as well as which version of Powerpoint ? Also, are you able to open these presentations by themselves?
